07 pete 386 stereo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stark21, Sep 17, 2011.
  1. stark21
    stark21 Light Load Member
    129
    5
    Jul 25, 2010
    Virginia Beach
    is there a Amp that powers the speakers in the truck, I am going to remove the factory stereo and put in either a alpline or kenwood and don't won't loose the good sound from the speakers.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I'm sure he has his stereo by now. :)
    You can go the route you said or you can wire from scratch with a different system. Most drivers that replace a stereo is because they want higher end equipment. Using factory wiring is not something you want to use in them cases because of the small gauge wire.
    If stark just happens to come back around, the amp is built in the unit.
  4. txviking
    txviking <strong>Trucker Geek</strong>
    344
    73
    Jul 18, 2009
    Florida
    I put an Alpine into my 379. Almost fried it, too -- as it turns out, there are TWO physically identical power connectors back there, but they are electrically different.
    As luck would have it, I noticed the smell of burnt plastic right away. I immediately unplugged it and, after some digging, realized I'd used the wrong connector. The stereo survived.
    I really wish Peterbilt would've keyed those two connectors differently, though. I still don't know what the other one is for. :mconfused:
