'07 Peterbilt Door Handles
Discussion in 'Peterbilt Forum' started by ToddyRich, Apr 4, 2013.
  1. ToddyRich
    ToddyRich Bobtail Member
    20
    4
    Jun 4, 2008
    IOWA
    Recently my door handles have been becoming more and more difficult to open, and they stick in the open position, I even have to push the outside door handle back in. I've sprayed tons of lube where i can, it helps a little, but still sticky
    Are these door handles a pain to replace? Do I need to replace them, or is there some other remedy?
  3. starsonwindow
    starsonwindow Medium Load Member
    569
    165
    Feb 2, 2012
    Phoenix, Arizona
    Plastic what are you spraying them with? Sounds like you may need to replace the drivers, why don't you swap it with the passengers side? If no one uses the passengers door, If you are solo then you can get a few more miles out of them before you have to replace them.
  4. ToddyRich
    20
    4
    Jun 4, 2008
    IOWA
    I'm spraying them with wd-40, i wonder if that is causing them to gum up and make it worse...the passenger side door handle is almost worse to open. I'm pretty sure the door handles wont swap from right to left on this ole girl, I'm looking at replacing all three of em, two on the left side (drivers door and bunk door) and the passenger side door handle. Looks like i need to buy an door panel removal tool.
  5. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    911
    Mar 16, 2013
    So basically their acting like the pre 05 handles?
  6. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I was thinking of WD40 too. Might try pressure washing the locking mechanism then soaking with WD. Keep in mind that WD evaporates. It might be best to use Lithium grease.
  7. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I had the same issue with mine and WD40 took care of it.
    Might want to try something like PB Blaster. It "walks" into crevises.
    TwinStickPeterbilt Thanks this.
  8. TwinStickPeterbilt
    707
    911
    Mar 16, 2013
    PB blaster is the ####. Brake parts cleaner I know weird could also help you.
    MJ1657 Thanks this.
  9. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Someone told me about the pb walking so I took a bolt and clamped it in my vise. Sprayed pb on the bottom of the bolts threads and let it sit overnight. When I checked it in the morning it had crawled up the bolt.
    I thought that was kind of neat.
  10. pushbroom
    pushbroom Road Train Member
    1,791
    7,405
    Sep 1, 2012
    Shouldn't need any sort of special tooling to change them. They are not too hard to do. Door handles are not interchangeable side for side. Sometimes lube will free them up if caught early enough. If you do change them, either order them keyed to your current key or swap the key part. If you know what your doing, it is possible to grind the new lock to work with the old key.
  11. Harley Tramp
    Harley Tramp Bobtail Member
    13
    Aug 28, 2013
    Just fixed mine today. Drivers door was hard to open. Had to pull the latch and push on the door to get it to open. Was ok from the inside. I lubed it up good with Zep lubricant and it works fine now. I guess i will see how long that lasts.
