09 columbia htr mtr fuse location
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by o1reb, Oct 6, 2026.
  1. o1reb
    o1reb Light Load Member
    53
    22
    Apr 28, 2012
    bedford
    need some help main feed to blower mtr dead can't find fuse location thanks
  3. Concorde
    Concorde Road Train Member
    5,948
    21,225
    Jun 29, 2016
    West Melbourne Florida
    I put your thread title into a google search..
    On a 2009 Freightliner Columbia, the main heater/blower motor fuse is located inside the main fuse panel behind the glove box on the passenger side dashboard. [1]
    The critical detail to note is that the blower motor fuse is typically not labeled on the fuse diagram. [1, 2]
    Specific Fuse Positions to Check:
    Look at the lower-left side of the fuse panel (in the same row as the relays): [1]
    • 30 Amp Fuse: This is the dedicated fuse for the cab blower motor. It is often plugged into what looks like an unmarked micro-relay socket slot rather than a standard fuse line. [1, 2]
    • 5 Amp Fuse: This sits right next to or staggered with the 30A fuse and controls the HVAC control head / dashboard module. Note: If this 5A fuse blows, the entire climate system (including the blower) will die. [1, 2]
    • 20 Amp Yellow Maxi-Fuse: Usually labeled "HVAC", but this controls the A/C compressor clutch, not the fan. [1]
    Getsinyourblood, Ddh77777 and o1reb Thank this.
