09 international prostar electrical issues
Discussion in 'International Forum' started by Krhaulin, Dec 4, 2016.
  1. Krhaulin
    Krhaulin Bobtail Member
    30
    5
    Dec 4, 2016
    I have a 09 prostar with the Cummings isx motor, the windshield wipers will not cut off. The brake lights won't cut off. Nothing on the right side dash works such as fog light regen dump suspension etc? Just put 4 new batteries in it. I don't know if it's a wire issue. Or ECM or body controller? Thanks for your time
  3. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    Before you do anything, disconnect the main hot lead at the batteries and wait 15 minutes before you put it back on. Make sure the key is off the whole time.
    Most of what you're describing have "virtual" fuses in the body control module and a hard reboot fixes things a surprising amount of the time.
    Frank
    Krhaulin Thanks this.
  4. Krhaulin
    30
    5
    Dec 4, 2016
    Thanks frank. I will try that tomorrow.
  5. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    Double check your battery connections, then check the mega fuses near the air cleaner housing at the firewall on the left hand side. You might have popped one or both.
  6. Krhaulin
    30
    5
    Dec 4, 2016
    I unhooked battery and let sit for 20 mins. I also checked the mega fuses one was shot, replaced but still have same issues. The info center is saying electrical fault abs module. Would abs module have anything to do with the problems stated above. THanks
  7. Heavyd
    7,830
    6,282
    Feb 4, 2009
    The ABS module is a symptom, but not the cause. Sounds like you still have power issues. If the ABS does not power up, the cluster will freak out and display that message. When you key on, can you hear the start-up clicks from the modulator valves? If not, this means the ABS is not turning on at key on and you still have power issues to those circuits. Also, pull out the windshield washer breaker and let the wipers cycle 4-5 times and see if they stop.
  8. Krhaulin
    30
    5
    Dec 4, 2016
    Heavyd thanks for the info. What started all of this was the truck didn't have a lot of pulling power. Mechanic said was part of the egr on back of motor. He fixed the horsepower part but in doing so he took half the dash out to get to it. So could it be something he did putting dash back on? Before I took it to him I didn't have any of these problems.
  9. Heavyd
    7,830
    6,282
    Feb 4, 2009
    Have him double check the load shedding relay. It is mounted on the rear engine cover under the center console. If it is unplugged or came disconnected, you will lose half the truck.
  10. Krhaulin
    30
    5
    Dec 4, 2016
    Heavyd I brought the truck home he said he was busy it would be weeks before he could look at it again. Could you explain to me easiest way for me to do it. I have half the dash apart all ready. Thanks
  11. Krhaulin
    30
    5
    Dec 4, 2016
    Nevermind heavydo. Saw it on one of your older threads. Thanks
