09 international prostar speedometer stuck
Discussion in 'International Forum' started by brian8608, Oct 28, 2014.
  1. brian8608
    brian8608 Bobtail Member
    4
    Oct 28, 2014
    I have a 09 international prostar and the speedometer is stuck on mph and its not getting the power its supposed to and the speedometer does its sweep but then goes all the way pass 75 and stops at mph any advice please help
  3. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    When you say it is stuck on "MPH", do you mean it is pointing straight down? If the needle is pointing straight down that is a diagnostic indicator that there is fault with the speedo sensor or circuit. Since you are also experiencing low power this is also symptom of a failed vehicle speed sensor or circuit as the engine will derate power without a valid speed signal.
    QUALITYTRUCK and brian8608 Thank this.
  4. brian8608
    4
    Oct 28, 2014
    Quick question what do you mean by circuit and if I put the speed sensor in will that fix my speedo problem
  5. Heavyd
    7,831
    6,282
    Feb 4, 2009
    The circuit is basically the wiring itself from the sensor to the ECM. The problem is either the sensor or wiring. You have a 50/50 chance of fixing it by simply replacing the sensor.
    Packer1077 and brian8608 Thank this.
  6. brian8608
    4
    Oct 28, 2014
    Hey thanks for the info and response. Got a sensor on order but how would hookung that up reactivate my speedo
  7. Heavyd
    7,831
    6,282
    Feb 4, 2009
    The system will continuously keep testing the circuit, once the fault is gone it will restore itself to normal. If the check engine light is on, you might have to turn the key on, then off for 30 seconds, then back on.
    brian8608 Thanks this.
  8. brian8608
    4
    Oct 28, 2014
    Thanks heavyd you were 100% right just replaced the sensor and everything is back to normal thank you you saved me a lot of money
    John E., Humblepie and Heavyd Thank this.
  9. Heavyd
    7,831
    6,282
    Feb 4, 2009
    Good, happy to help!
  10. Bigjoe33
    Bigjoe33 Bobtail Member
    I have a 2012 international prostar, when I'm on the road going up hill, it slows down and the rpm needle will go back and forth, and sometimes it won't go to the 10th speed. Any help about what is wrong with it?
