1 Trailer brake locking up
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by homesick, Oct 4, 2021.
  1. homesick
    homesick Light Load Member
    161
    8
    Nov 26, 2007
    memphis,tn
    Trailer brakes on the left front Axle keeps locking up and putting flat spots on the tires replaced the s cam and bushings,new brakes and drums slack adjuster,abs valve and brake chamber but still locking up when you have to make a sudden stop. Any ideas what it can be?
  3. AModelCat
    164,647
    Suspension issue not allowing adequate weight onto that corner?
    Big Road Skateboard Thanks this.
  4. Big Road Skateboard
    7,096
    40,271
    May 2, 2021
    Flatbed with not much weight? Like @AModelCat said. For some reason you've got no traction there.
  5. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    I forgot to mention it's a 53 dry van
  6. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Greese/oil? Broken gear?
  7. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Given that youve relaced everything but the axle itself, 2 things come to mind
    1. When replacing the slack adjuster and chamber, mechanic didnt set slack adjuster to correct length
    2. The way the slack adjuster mounts is messed up and allows too much flex/is hanging
  8. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,900
    Sep 20, 2015
    Southern Ontario
    Our stepdeck trailer did that. Had a brake job done both sides for front axle of a tridem.
    Thought the brakes needed breaking in but it kept doing it. Locking up, sliding tires.
    I backed off the slack adjuster a bit more to allow more room for breaking in.
    Still does it. I checked the other 2 axles brakes as well. They appeared fine, had lining and working fine but more likely glazed and not braking enough so I replaced all of the pads and drums. The front axle was working harder than the other two.
    Trailer has been fine since.
  9. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    I replaced all the brakes and drums still locking up
  10. nikmirbre
    nikmirbre Road Train Member
    5,585
    10,338
    Jul 27, 2011
    High Point NC
    My RGN does this at times if I set the ride height to manual and don't have the same setting on all 3 axles.....id say you have a suspension issue.
