1 Trailer hub running 15° hotter?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by double yellow, Aug 31, 2014.
  1. Alaska76
    Alaska76 Road Train Member
    1,228
    1,654
    Jan 20, 2014
    Inland Empire, WA
    Were I, you, I would have those bearings out, cleaned, and be taking a close look at them for signs of failure. Chances are that they are breaking down, probably looking dull and matte gray on the weight bearing surfaces, rather than bright shiny chrome in appearance.
    If it were a brake adjustment or other brake related issue, the drum temp. would be a clear indicator in that area- outer circumference of the drum.
    Hammer166 Thanks this.
  3. double yellow
    5,945
    10,066
    Aug 28, 2011
    State of Jefferson
    It is the older style grease-packed hub (1998 Monon dry van). No window, no oil plug... Hub temp reached 150* today (compared to 100ish for the others) with an empty trailer! Guess I'll play Sacramento-area trailer shop roulette on Monday -- still haven't found a good mechanic in the area...
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Seriously, 10-15 degrees? I checked the tires on my truck after a drive, one steer was 116, the other was 120. Should I be concerned? They were both the same pressure cold when I checked them...
  5. double yellow
    5,945
    10,066
    Aug 28, 2011
    State of Jefferson
    2 weeks ago it was the same temp as the rest
    1 week ago it was 15 degrees hotter
    today it was 50 degrees hotter
    can't say it hasn't been giving me warning...
  6. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    When was the last bearing replacement and what would you loose by replacement them?
  7. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    I think these hubs are none serviceable, the cost for the hub assembly is over 1000 bucks. I think the spindle is different so you can't put the other hub on it. From what I've seen you are about to fix it on on the shoulder somewhere. Good luck
  8. Davidlee
    419
    156
    Aug 31, 2012
    Some of those non-serviceable hubs can be replaced under warranty. It doesn't matter the age. If that's the case, they will send you brand new axles complete with wheel ends. Good lunck!
  9. russellkanning
    russellkanning Medium Load Member
    640
    142
    Jan 22, 2012
    Frost, TX
    man that sure doesn't sound good
  10. double yellow
    5,945
    10,066
    Aug 28, 2011
    State of Jefferson
    Back from shop #2 -- this one a brake, tire & alignment specialist. They took it apart, found nothing wrong, threw in new seals and repacked new grease. Hub still 40* hotter after a 15 mile deadhead.
    Is it possible that airbag is putting more pressure so that wheel has more weight on it? The trailer was aligned a month ago and tracks straight...
  11. wedge542
    wedge542 Light Load Member
    241
    31
    Aug 13, 2007
    roll tide
    you would be able to pick that up with your temp gun if tires hotter on that asemb.,,i think i woulda had those bearings and races replaced for a piece of mind.
    double yellow Thanks this.
