1 Trailer hub running 15° hotter?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by double yellow, Aug 31, 2014.
  1. double yellow
    5,945
    10,066
    Aug 28, 2011
    State of Jefferson
    Yeah, I told the service writer if they couldn't find anything to rebuild it, but apparently I should have specified using new parts :biggrin_25526:
    Tires/brakes are the same temp as the others so I guess uneven weight/alignment are not likely.
  3. tesla4all
    tesla4all Light Load Member
    176
    33
    Dec 8, 2008
    Southeastern US
    temp differentials like you are experiencing shout problem somewhere for sure... I too use an ir gun to check tires..hubs.. and many other problem areas on my truck... great time saver ... but same as you ..with pressures same cold.. new spindle.. bearings whatever,.. there are always going to be different temp readings, a few degrees. but yeah, with that big a difference at that one position, there is an obvious problem. I'll stay tuned to see what you find. Good luck!
  4. rank
    rank Road Train Member
    9,907
    113,497
    Feb 11, 2010
    I have to say you're attention to detail is impressive. How many drivers would ever notice that....one in 500? Most wouldn't even know until after it caught fire.
