10 spd to 13spd or 18spd conversion
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Feb 15, 2015.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    i'm planning on swapping out my 10spd for a 13spd or 18spd will this be a straight out swap or it will require drive shaft to be shortened?
    the truck is a fld120 daycab 179" wheel base Detroit series 60
  3. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Need shortened drive shaft.
    SHO-TYME and truckerbangin Thank this.
  4. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    13 and 18 have an additional auxiliary box on them.. longer transmission, so a shorter driveshaft will be needed. Also, you'll want to know what the final drive ratio on your current transmission is, because that 13 or 18 is going to be a .73 or .74 OD. If you're running, say, 10 direct and 2.64s, you won't appreciate the difference very much, but if you're running a .74 OD already, then of course a .74 13 or 18 speed will be more the same, and the difference with a .73 will be very slight.
    truckerbangin Thanks this.
  5. truckerbangin
    268
    45
    Jan 22, 2013
    i'm currently running a fro 15210c with 3.90 rears
  6. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    keep the 10 speed and install 3.55 or 3.70 rears after a cost analysis between the trans replace or rears.
  7. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    You will love the 18B or a 13A. The 18B will have a lower low and reverse.
  8. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    Trans is cheaper I bet.
    Brettj3876 Thanks this.
  9. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    My last two trucks had 18 speeds. Bought this one for the 6NZ, but it had a 10 speed. It was expensive but I pulled the 10 out and put a reman 18 in. Expensive, Rush peterbilt and you eat most of the core. Would I do it again? Yes!!!!!!!!
    Black389, Trugo and Guf Thank this.
  10. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    I a mbn have 10 sp 16210c with 3.70. tuned to 500 hp. Has .73 on 10th gear. Only gets 5.1 mpg. Best I had is 5.7 mpg after valve adjustments. I had thoughts of putting 13 sp on it. What's your advice other than the cost?
  11. WitchingHour
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    If you're doing it for the fuel mileage, those 3.70s are gonna be your biggest hindrance.
    russtrucker Thanks this.
