10 speed blues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hopeaholic, Jul 28, 2024.
  1. Hopeaholic
    Hopeaholic Bobtail Member
    47
    15
    Nov 7, 2018
    So while pulling the engine/transmission out of an old international dump truck, the chain on the back of the engine broke and the cast iron transmission cracked in both front and back sections. Ouch.
    The gears and parts inside are likely still good (TBD) and I'm looking for a good used case to reassemble with new gaskets, seals, etc., etc. as good used ones are pretty pricey and most have a core charge (my old core isn't likely to get full credit).
    I'm having trouble finding a like for like core at a reasonable price and wondering whether the cases are all the same on the 10 speed models. The one that broke was an RT6610 with a 1.75" spline an a 28.3" overall case length. 10 speeds with 2" splines are obviously much easier to find and look very similar but the transmission length showing up on the eaton charts for most of those is 28.9".
    I did find an a used RTF910 at a reasonable price. It's 200 pounds heaver and would probably require some extra support. The seller claims it has a 1.75" spline. Maybe that's the best route as I'm wanting to preserve the 10 speed gearing I have now rather than going down to a 6 speed.
    Looking forward to feedback and ideas from anyone with experience on these.
    austinmike Thanks this.
  3. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    The 610 and 6610 are totally different animals that the “big” transmissions like the 910 and such
    Nothing will interchange other than probably the clutch cross shaft.
    I would also guess you have a sae2 housing and most of the big transmissions will have a 1…a 2 should be available but might be hard to find.
    A 613/6613 will have the same front box but not the rear.
    I have no idea where you are located but I do have a 7 speed from a 90s ih single axle truck tractor if that’s of any interest pm me
    austinmike, Oxbow, Hopeaholic and 2 others Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I put a 9510 in place of a 7 speed once in a fertilizer spreader truck. The bell housing was hard to find and you cannot get that for anything above a 9 series. Have to have one with the correct top plate location but the old shift tower bolted right up. Just shortened the shaft, shift knob and no rear support. Worked out very well and easy.
    austinmike, Oxbow, W923 and 1 other person Thank this.
  5. Hopeaholic
    47
    15
    Nov 7, 2018
    Thanks W923; does your 7 speed have SAE2 bell housing and 1.75" spline?
    austinmike and Oxbow Thank this.
  6. Hopeaholic
    47
    15
    Nov 7, 2018
    Thanks BoxCarKidd; did the 9510 have an SAE2 bell housing and 1.75" spline?
    austinmike, BoxCarKidd and Oxbow Thank this.
  7. W923
    1,419
    4,389
    Feb 28, 2022
    Yes
    Since I posted that I have been thinking I might know where a good used 6613 is
    austinmike, Hopeaholic and Oxbow Thank this.
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    i have a 10spd in the back of my shop not sure the numbers but came out of a 379 worked great could probably be had cheap southern pa area
    W923 Thanks this.
  9. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    I do not remember the SAE number. It was the smaller one behind a 3126. Took the 2 inch shaft out and put in the 1.75 shaft. No big deal.
    W923 and Hopeaholic Thank this.
  10. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    I found that smaller housing from TH Evans in Athens. They are an LKQ deal now.
    W923 Thanks this.
  11. Hopeaholic
    47
    15
    Nov 7, 2018
    Thanks little cat 500, I'm 99% sure that is the bigger 10 speed with the 2" spline that weighs around 700 lbs (about 2X more than the RT6610).
    W923 Thanks this.
