10 speed to 18 speed
Discussion in 'Questions From New Drivers' started by Danicorobinson12, Dec 10, 2019.
  1. Danicorobinson12
    Danicorobinson12 Bobtail Member
    6
    7
    Dec 10, 2019
    So when I learned to shift on my 10 speed blutec freightliner I was told up shift and down shift at 1500 and I can always know what gear to go to by adding the double digit speed I'm going like single numbers. example:35 mph=3+5=8th gear
    And so on and forth how do I know what gear to goto or that I'm in with 18 speed and what the sweet rpm is for upshifting and down I have a drive test coming I need tips
    Thanks
    FlaSwampRat Thanks this.
  3. Powder Joints
    7,987
    8,403
    Sep 25, 2007
    Rosamond, SoCal
    This post sounds like your getting ready to learn to drive. It depends on the gear ratios ordered, not a big difference on technique between them.
    Drop by utube lots on videos on both.
    Bean Jr. and Lepton1 Thank this.
  4. Danicorobinson12
    6
    7
    Dec 10, 2019
  5. Danicorobinson12
    6
    7
    Dec 10, 2019
    I can drive 10 speed fine no problem but what I'm saying is 18 speed is different YouTube has no videos of what rpm the guys are shifting at through the gears
  6. Powder Joints
    7,987
    8,403
    Sep 25, 2007
    Rosamond, SoCal
    Forget about the gears and just drive the truck, you don't use the exterme low range much unless your doing heavy haul.
    Woodys, G13Tomcat, Lepton1 and 4 others Thank this.
  7. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Just drive it as a ten and don't use the splitter on the side if you are just road testing empty.
  8. Powder Joints
    7,987
    8,403
    Sep 25, 2007
    Rosamond, SoCal
    Yup, just drive forget the lowend till you learn to drive it.
    Danicorobinson12 and FlaSwampRat Thank this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Forget about stopping the earth.
    PAY ATTENTION to whatever cautions exist on your transmission plate.
    No need to split if the engine is happy and the tractor is purring without that horrible bounce house HOPPING.
    In time you will become for lack of a better word become intimate and one with the 18 speed.
    SoCalRed and Danicorobinson12 Thank this.
  10. Danicorobinson12
    6
    7
    Dec 10, 2019
    Yup for sure guys I'm going to be hauling construction equipment here in Seattle for a paving company and driving transfers all the trucks are 18 so thanks for advice
    Lepton1 and FlaSwampRat Thank this.
  11. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    Do you know what engine is in the truck? Find that out. You can see the serial number and specs on a plate either on top or on the side of the engine. Then look up the rear end ratio. Those two pieces of information are more important to me than the type of transmission.
    I drove hundreds of trucks on a drive away basis for the oil industry, with a wide range of specs. Almost always the rpm's to upshift were north of 1500, sometimes around 2000 rpm's. Try shifting at 1500 and you end up lugging it and having to drop a gear or two.
    If you are hauling construction equipment in the Seattle area the trucks are likely going to be specced like an oilfield truck, since you have a lot of steep hills to contend with.
