10 speed vs 13 speed????
Discussion in 'Ask An Owner Operator' started by CapeBuffalo, Sep 17, 2013.
  1. Truck609
    Truck609 Light Load Member
    238
    197
    Dec 17, 2011
    Arizona
    I Remember When The Super 10'S First Came Out..... I Think ItTook All Of A Day Before They Were Referred To As "Stupid 10'S"
    Junk, Junk, Junk!
    And Whoever Asked About This Dang Capitalization, No Its My Old Droid Razr MaX.
    milskired Thanks this.
  3. rollin coal
    rollin coal Road Train Member
    13,722
    28,276
    Mar 29, 2008
    TN
    I had a super10 and a lightning10 in some company trucks. I liked it. You could bump the shifter out and back in on splits and it shifted much faster. Never did tear any rears out of a truck with one that sounds more like driver error than a transmission issue snowwy :-/
  4. Hammer166
    7,624
    27,923
    Aug 18, 2007
    ~8600+' and loving it!
    Snowy....please... this just isn't true.
    Mine does it to!
    A super 10 is an 18 with two gears missing in the main box. It range shifts when you go from the center gate to the right gate, and only has 3 gears in main instead of 5.
    As long as they weren't shifted into neutral at high speed, there was nothing wrong with them. Drivers who kicked them into neutral coming down ramps and up to lights soon tore the synchronizer out of them.
    Ditto!
    Sublime and rollin coal Thank this.
  5. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    ir
    final drive ratio will determine your cruising rpm's. I run 3:36 gears, 1,400rpm is 68mph, sweet spot in my DD60 14L. Tire size, too. What kind of loads you'll be pulling and the roads you'll be pulling them on - should be the starting point for making selections.
  6. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    yep. and so did the 6 drivers after snowwy drove it.
  7. rogueunh
    rogueunh Road Train Member
    1,086
    23,188
    Jan 4, 2011
    The 13 speed in my fleet is doing 65 mph at around 1200-1250 rpms. At 1500, well it's breaking speed limits for sure, lol.
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I have Eaton Fuller 13 manual, 1,170,000 miles stll works great , I spent $ on 3 oil changes only . Works better than my last truck with 10 manual especially pulling heavy loads uphill or heavy in 55mph zone. I remember the 10 was hard to keep in proper gear /Rpm power driving heavy on 55mph in Ohio/Illinois when the truck limit was 55 and bears in every bush.
