10 to 13 speed
Discussion in 'Ask An Owner Operator' started by Loadx, Dec 11, 2020.
  1. Loadx
    Loadx Bobtail Member
    13
    10
    Jun 27, 2020
    Currently have a crap 10 speed Spicer that's on its last leg and thinking of switching to an Eaton RTLO 10 or 13 speed. Anyone who went from 10 to 13, did you actually see any kind of real difference or benefits? I feel like it's probably not much of a difference, but I've never done it. Thoughts?
  3. jamespmack
    216,478
    Biggest benefit is 300 rpm drop between top gears instead of 600 rpm. I would swap one everytime.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    If you primarily run on flat ground I don’t think you’ll really see any difference or advantage depending on what speeds you typically run and rear gears. If you run in hilly or mountainous conditions, then the 13 is definitely the way to go.
  5. jamespmack
    216,478
    I run mostly flat and wouldn't want to go back to a 10. I wouldnt swap one just because. But if it was out and needed rebuilt, absolutely!
    Nostalgic, Coffey, Opendeckin and 8 others Thank this.
  6. Oscar the KW
    12,247
    28,120
    May 19, 2011
    No way I would ever go back to one either. I’ve had an 18 in my last four trucks, I wouldn’t go to a 13 after having an 18 either.
  7. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
  8. abyliks
    abyliks Road Train Member
    4,123
    9,715
    May 2, 2010
    ludlow MA
    Just needs to be shortened
    depending on the model the 13 speed could have a lower low gear and a taller, shorter, or equal to OD of the 10 speed.
    I would absolutely scrap the 10 speed
  9. Hammer166
    7,605
    27,793
    Aug 18, 2007
    ~8600+' and loving it!
    And surprisingly, I missed the 13 more on the downhills than the climbs, back when I ran a 10 for a while.
    Coffey, feldsforever, Bean Jr. and 3 others Thank this.
  10. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    May be I'm missing something here I've had this 10 speed with a 370 final drive since 1997 no problems. What gives?
  11. jamespmack
    216,478
    I'm mixed on this. Drove many 18's and split the bottom when really heavy. 100k gross and 13 works just fine for me. But I do no off road work. Most people are just fine with either.
    Coffey, Bean Jr. and blairandgretchen Thank this.
