102's on a Pete 579???
Discussion in 'CB Radio Forum' started by *Coyote*, Apr 9, 2016.
  1. *Coyote*
    *Coyote* Bobtail Member
    49
    19
    Jul 18, 2014
    Louisville, KY
    Has anyone seen or have any suggestions on mounting a 102 on a Pete 579? Putting my Texas Starr 667 in my new Pete and trying to come up with a mounting location for a 102. At first I was thinking off the back of the sleeper till I realized I can't get 24" of clearance off the back of my sleeper with my hose rack where it is. No, it's not moveable, or at least I'm not moving the dam thing. The only idea I've come up with would be to use a flat bar pickup truck mount off either one of the bolts on the rear of my drivers side top steps, so it would stick up where my stacks would be. I run grass burner exhaust. Or, same mount off the support rod on the rear drivers side front bumper. But I'm looking for suggestions if anybody else is currently or has used in the past a 102 on a 579.
    Coyote
  3. stacks
    stacks Road Train Member
    1,547
    850
    Oct 27, 2011
    Emerald Isle
    Do post some pics when you finally decide that would be interesting to see
    rabbiporkchop Thanks this.
  4. *Coyote*
    49
    19
    Jul 18, 2014
    Louisville, KY
    Will do. Probably be a month
    TheDude1969 and stacks Thank this.
  5. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    I could be wrong but placing it anywhere alongside the all aluminium sleeper would make getting a good SWR reading hard. I think a better location is the mirror mount like a Cascadia angled forward enough to clear 13'6". @volvo244t had a picture of his 102", same idea.
  6. *Coyote*
    49
    19
    Jul 18, 2014
    Louisville, KY
    Not possible on Peterbilt. Your right about the swr though. I'm just really nervous about the bumper mount getting hit or vandalized. Not to mention a coax run next to the motor is never a good idea.
    TheDude1969 Thanks this.
  7. Ridgeline
    22,727
    123,476
    OH please ;)
    YOU got a lot of room under the hood.
    Run the coax along the inside of the frame in some protective tubing like that spilt plastic stuff, make sure that it is not exposed to oil (directly) or exhaust heat and it will be alright.
    rabbiporkchop and TheDude1969 Thank this.
  8. *Coyote*
    49
    19
    Jul 18, 2014
    Louisville, KY
    Thanks for this, I needed a good laugh. It's a Pete! It marks its territory constantly.
  9. TheDude1969
    807
    823
    Jun 10, 2013
    Joliet, Il
    If its not possible, then I'd consider the the poor swr on the step vs. rewiring new coax to the original mount with a shorter antenna. <--my guess is you'll find better performance from a shorter antenna and better swr, than a 102 performing at 1:2.0+ with most of the counterpoise reflecting parallel?
  10. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    If the body of the truck is all plastic why not stack a couple dipoles
  11. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    Have to be from stock location, mirror mounts won't attach as there are no fasteners accessible. Not sure how the spot mirror mount would work on the passenger side for that purpose.
    *Coyote* and TheDude1969 Thank this.
