10spd - 13 - 15 or 18 spd
Discussion in 'Experienced Truckers' Advice' started by Snow Walker, Mar 18, 2017.
  1. Snow Walker
    Snow Walker Light Load Member
    In all the years I have been trucking, one of the most common questions I have heard and have been asked by newbies and really don’t know how answer with conclusive feed back; "which transmission would you prefer?"
    My first truck in 1958 was an Autocar (I was still a teenager) that had a 5 + 4, 10 speed that was similar to playing with two logs in a cramped space. The old Autocar was mostly off road, but ran many highway miles. My next truck was a a DiamondRio with a 10 spd split. The Rio was acceptable but if I was anywhere near a hill, I would wear out my arm yanking that sloppy old stick all over the cab.
    My first KW 100 (COE) had a Road Ranger 10 that was great for the flat road work but the absolute ####* in the mountains. My first 13 spd (Eaton) was my favorite and still was on retirement. I feel it was ideal for any hwy. work. For about 30 years I bounced back and fourth between 13s and 15s. The 15 was a great all around tranny, I thought, but for highway in a modern tractor pulling 80,000; however, a 13 spd did the job just fine, in my personal opinion.
    My next shot was with a Spicer 18 in a KW T2000. (In my estimation, they are completely over done & useless except for mountain work with a heavy load.)
    **I have never used an automatic**
    How would you guys answer the question or recommend to a newbie?
  3. Heritage11
    Heritage11 Light Load Member
    120
    274
    Jan 6, 2017
    I've run 10's and 13's and the 10 auto.
    I like the 13. It's pretty versatile for a typical otr mix of loads/terrains.
    The auto I thought completely sucked. I won't drive another one.
    The 10 is good for the training companies for obvious reasons but I didnt like it at heavy weights or in hilly terrain.
    I'll take the 13 any day of the week
    Bean Jr. and G13Tomcat Thank this.
  4. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    In over 45 years of driving a semi,I'm pretty much in agreement with you.My last truck had a 15,good trans,but a 13 OD was always my favorite.Had a 13 direct for a couple of years,too,where you split under your top range.Automatic,in a big truck?What's that?
    Bean Jr., clausland and Snow Walker Thank this.
  5. clausland
    clausland Road Train Member
    1,933
    11,068
    Dec 5, 2014
    North Woods
    I guess it all depends on what type of hauling you're doing. For ordinary run of the mill OTR reefer work (45k # loads), I always preferred a 13, basically because of the half gear options on grades. I did run S/A Mack U models for a while, two had the Mack straight 5 (300 Mack), and one had a 10 RR. For the type of work we were doing, I didn't notice much of a difference, due to light loads. I'd go from 2-4-6-7-8-9-10 usually on the 10 RR anyway.....
  6. Ridgeline
    22,734
    123,590
    18, drive it like a 13 if you want.
  7. Vic Firth
    Vic Firth Road Train Member
    1,843
    4,307
    Jan 19, 2016
    Indiana
    I've driven more 10 speeds than any other type but if I were to spec out my own truck it would have a 13 speed.
  8. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    I prefer 18, but a,13 with low enough reverse isn't bad, either.
    I'm happy with a good running engine no matter what the trans, and I learned on 9 speed Eaton and Meritor.
    Hammer166, Ezrider_48501 and G13Tomcat Thank this.
  9. AModelCat
    164,908
    I've only ever driven 15's and 18's. I like the 18 best. Drive it like an 18, a 13 or heck just stick to the H-pattern and split the top gear.
    dustinbrock and G13Tomcat Thank this.
  10. LandslideRich
    LandslideRich Light Load Member
    292
    268
    Jan 13, 2017
    Charlotte, NC
    I like a 13 speed because if you need just a little bit to crest a hill you can just drop half a gear. Same for an 18 I guess but in all the time driving them I never felt the need to split the bottom half. Seems these days the most common is the 10 speed which is what I have now.
    G13Tomcat Thanks this.
  11. xsetra
    xsetra Road Train Member
    5,198
    7,148
    Aug 21, 2011
    Depends on duty. Typical legal load, 10 works. I like the 13. 15 is Ok, I drive my 15 like a 10 but it is nice to have the low gears for starting on a hill , off road, snow or mud.
    G13Tomcat and Snow Walker Thank this.
