110,000 lbs crane track
Discussion in 'Heavy Haul Trucking Forum' started by bonder45, May 25, 2021.
  1. bonder45
    bonder45 Road Train Member
    1,803
    5,456
    Oct 2, 2011
    Williston, ND
    Okay, so I’m used to just “running it” because well I’ve worked for companies that didn’t care about their equipment or how much weight you put in it.
    Now that I have my own stuff, I want to make sure I’m legal and well, the trailer can hold it.
    I have a customer that wants me to haul a 110,000lbs crane track.
    Can I put that on a 4 axel flatdeck with a 4 axel truck or will I need Jeep’s and boosters, etc.
    Here’s where i was told it was okay - 100k track on this setup.
    cke, Landincoldfire and Kyle G. Thank this.
  3. AModelCat
    166,504
    That's some hella flex on that deck!
  4. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    How hi it will be on that trailer will tell you if you will have to pay for escort/s and how much extra you have to charge them?
  5. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    If you look at the trailer’s vin number plate, there’s a gvwh there too, that will tell you if your trailer can hold it.
  6. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    What he said. It is all about trailer build. I can put 100k on the deck of my all aluminum 48 spread and 60k in 4ft. Because that's the specs I wanted. No 2 trailers are the same. Look at the spec plate or the build sheet if you have it.
    Shawn2130 Thanks this.
  7. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,902
    Sep 20, 2015
    Southern Ontario
    This trailer is a 104,000 lbs according to the gvwr tag.
    Our steel tridem stepdeck easily held 50 tons of concrete slabs when we did local back roads.
    It did not bend like that 4 axle in the OP’s picture.
    Now, some older trailers look saggy instead of arched. Doesn’t mean it’s worn out or weak. Just the way it’s built.
    shooter19802003 Thanks this.
