12.7 Detroit adding jakes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pete0377, Apr 16, 2024.
  1. Pete0377
    Pete0377 Bobtail Member
    4
    Bought a 99 pete with a 12.7 Detroit. It’s not the original motor and the motor did not come with Jake’s. I’m wanting to add Jake’s and need help on deciding which Jake’s I need for the motor.
    06R0505674
    6067MK60
  3. MRMTRANS
    MRMTRANS Medium Load Member
    411
    441
    Apr 28, 2015
    Model #770 came on 1999 MKs, as you can see on the uploaded file. I believe model 790 will work as well because the injector, intake, & valve adjustments are the same for both engines. I'd go by the camshaft # to be sure. 790s are stronger than 770s because the lash is larger. Are you looking for engine brakes? I have both 2 piece and 3 piece Detroit engine brakes just sitting in my shop that I've kept around after parting unusable blocks. I would have to check model #s. I'll sell them dirt cheap.
  4. Pete0377
    4
    Yes looking to buy Jake’s. I just didn’t know which ones I needed so that helps a lot
  5. Wheelspinner
    Wheelspinner Bobtail Member
    I’m interested in possibly getting some of these used Jakes. I’m too new to send a PM. I have a Series 60 powered bus. Thx
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    765 770 are pretty common ether will work plus many more need a new injector harness and brake turned on in ecm plus switches if said truck is not equipped with
