12.7 detroit over heating...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, Jul 8, 2012.
  1. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    Okay this is a friends truck and it's been over heating. He replaced t-stats in it and it didn't help. So having to deliver a load took them off, but it's still running hot. 220 to 240 when pulling a hill it won't cool off even with fan. He got home replaced the radiator and water pump left the t-stats off, still no luck.. Any ideas? He says he's not losing any water either..
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    How old is his radiator?
    Has it it ever been cleaned?
    Outside AND inside.(i had a truck overheat because radiator was clogged inside)
  5. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    There are engines that will run hotter with no thermostats than with thermostats. Water goes radiator too fast and will not get cooled.
  6. MNdriver
    7,985
    4,372
    Feb 24, 2012
    They are new
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    My bad.
    I read too fast.
    I apologise.:biggrin_25521:
  8. MNdriver
    7,985
    4,372
    Feb 24, 2012
    no problem.
    Just might change your thunkin.
    Will be interesting to follow.
  9. brenes-built
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    The old one he cleaned with some cleaner sold to him by freightliner and then changed out the thermostats, then the radiator and pump..
  10. rebel127
    rebel127 Light Load Member
    296
    149
    Feb 28, 2011
    monroe ct
    Is it possible that the temp sensor is bad if the power is still good and the engine is not derating it could be simple. There are several sensors the gauge and the ECM use different ones. Just a thought.
  11. jbatmick
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    And a good one at that.
