12.7 detroit turbo problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Krhaulin, Oct 31, 2019.
  1. Krhaulin
    Krhaulin Bobtail Member
    30
    5
    Dec 4, 2016
    Hello. My dad wanted me to ask this question. He has a 98 classic with 12.7. He had the motor overhauled in dec/jan. Last two weeks the boost is around 12 instead of 28. And the fan is coming on more than usual(getting hot). He changed the boots on the Cac. Didnt help it. Today he is at truckstop in elkton md. Changing the turbo sensor. The turbo was replaced in Sept 2018. Other then it needing a new turbo or new Cac, what else can he check/do himself today. He is under load so.doesnt have time to go to dealership. Thanks
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    could be a boost leak or boost sensor going bad
  4. Krhaulin
    30
    5
    Dec 4, 2016
    Looks like will need new Cac. Soapy water found this. Thanks all. Resized_20191031_171907_164.jpeg
  5. Mike250rs
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    If you have the time to wait, take it to a radiator repair shop. Should be 1/2 price of new to have it repaired & pressure tested.
  6. Rideandrepair
    17,562
    56,898
    Aug 8, 2015
    Try Radiator works, now owned by LKQ, USA and Chinese versions, they were under about $700 and $400, respectively.
