12.7 head - 14L block
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Detroit series60, Jan 9, 2021.
  1. Detroit series60
    Detroit series60 Bobtail Member
    10
    I heard some people use a ddec 5 14L block and throw on a 12.7 ddec 4 head , while deleting all the egr stuff as well. I’m curious as to what the benefits are of doing this?? (More so what are the benefits of swapping the heads)
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    same head other than they use different injectors ddec4 use n2 injectors ddec5 use n3 injectors
    spsauerland Thanks this.
  4. mdbell26
    mdbell26 Bobtail Member
    9
    6
    Aug 11, 2017
    They are NOT the same head.
    The valves and combustion gas (air intake) ports are different on the EGR cylinder heads.
    The EGR (DDEC 4 & 5) intake manifold will NOT bolt to a pre-EGR head.
    The_Great_Corn Thanks this.
  5. Mav2021
    Mav2021 Bobtail Member
    Ok but using the non egr head and manifold from a non egr 12.7 liter, and installing it on a 14 liter egr engine, ....will it run , i have a 2001 freightliner classicxl 132 12.7 non egr with 2,000,000 miles on it, i also have an 09 freightliner cascadia egr with 900,000 miles on it, trying to marry the two trucks, (build one good one) eliminate the egr and keep the larger cubic inch or liters.... can it be done, i believe both are ddec 4 is the cam shaft the same , for both engines, i have a new turbo and injectors in the 12.7, but the blow buy is evident in high winds...lol, its been a really good engine, but i have the other truck for donation or just put new loaded 12.7 head on 14 liter engine, will it work
  6. Mav2021
    Ok question for the knowledgeable, i have a 2001 freightliner classic xl 132 with a 12.7 liter non egr, complete, runs , has 2000000 miles on it blow by is evident in high winds, good engine. But i also have a 2009 freightliner cascadia with 14 liter ddec 4 with egr and cooler, no def, can i reman the 12.7 liter head and install on the 14 liter and using all the manifolds from the 12.7 liter, and 2001 wiring harness with it run?? The 2009 engine 200,000 on reman, but egr cooler started to leak ... i wish to make one good truck from the two...will it work..
  7. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    It is 100% possible. I've got one in my shop I'm working on now. Depending on which model 14L you're starting with you'll most likely have to have an adapter made for the cam shaft. After that it's pretty straightforward other than some custom programming
    spsauerland and Vampire Thank this.
  8. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    Delete the 09 and run it as is
    jsnell Thanks this.
  9. Detroit series60
    10
    Yes can be done no problem. Just need the cam adapter plate they sell online (if using a ddec5 cam) but it’s a 2009 so I’m pretty sure the 09 is ddec 5 not 4. But otherwise that and some custom tuning and you’re good . I know a tuner who could help u out if interested
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    09 it's probably a ddec6
