12.7 Series 60- Issues after rebuild
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JoeyJunk, Aug 8, 2022.
  1. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    Just had an engine built. Not my original block. Everything under the hood is brand new. New turbo (171701). New exhaust manifold (PAI). New CAC. New muffler, same as what was on before (Donaldson M100465)
    This rebuild took waaaay too long with way too many mistakes and excuses. Took my first trip today and the truck is LOUD. Annoyingly loud. Wasn’t like this before. I checked everything. No soot marks anywhere yet. Everything is tight.
    The truck now has a bad vibration. It’s not smooth at all. New dampner. New bull gear. New motor mounts. Everything new.
    I am at my wits end. Had to live off my engine fund since this took so long. Granted this is a 98 FLD120 that was abused when I got it. Engine has plenty of power. Accelerates great. The noise and vibration was not present with the old worn out engine and components.
    Any help, advice would be greatly appreciated. I’m so mad I can’t think straight.
    bzinger and singlescrewshaker Thank this.
  3. 062
    062 Road Train Member
    6,354
    34,045
    Oct 20, 2013
    Where are you feeling the vibration?
    I would check carrier bearing for missing shims and re-torque the u-joints.
    Dino soar and JoeyJunk Thank this.
  4. JoeyJunk
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    Just sitting in the seat at idle. Can feel it in the shifter and in my seat. It’s not the normal smooth vibration of an engine idling.
    singlescrewshaker Thanks this.
  5. 062
    6,354
    34,045
    Oct 20, 2013
    That’s not good. Does it smooth out if you increase rpm?
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Did they use poly engine mounts?
  7. Bean Jr.
    Bean Jr. Road Train Member
    5,578
    9,943
    Mar 30, 2014
    Push the clutch in. If it goes away, it's from the clutch to the input shaft. If it doesn't, it's the engine.
  8. JoeyJunk
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    No it doesn’t.
  9. JoeyJunk
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    No. Got the hard rubber ones from Freightliner.
  10. JoeyJunk
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    No change.
  11. Star Rider
    Star Rider Road Train Member
    1,821
    19,802
    Sep 23, 2019
    Start simple , run the overhead and check that injector codes are correct.
    BoxCarKidd, Bean Jr., JoeyJunk and 3 others Thank this.
