13 speed 2.79 rears
Discussion in 'Freightliner Forum' started by macgyver1267, Nov 18, 2013.
  1. macgyver1267
    macgyver1267 Bobtail Member
    20
    My '99 Classic has finally worn out the Rockwell 9 speed after 1.6 mil. Want to upgrade to 13 speed but not sure that will work with the 2.79's. Any knowledgeable ideas? And if it will work where can I get a 16 series reasonable ($1200?) in the Southeast?
  3. drover2000
    drover2000 Bobtail Member
    34
    19
    Aug 14, 2012
    Indiana
    Here is an article from the Pittsburgh Power guys:
    http://www.tenfourmagazine.com/PerfZone/2009/6.html
    macgyver1267 Thanks this.
  4. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    It will work you will just have to cruise down in direct 11th gear instead of up in the top 2 OD gears. So you'll be up in 7 over or whatever gear its considered I have an 18 so it'd be 7 over on my trans.
  5. wore out
    wore out Numbered Classic
    17,368
    215,646
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    As long as you have the low end to start a load nothing says you gotta cruise in high gear. I have a double over but gets me in trouble financially when I use it. I always drop to direct for 6percent grade or more but I try take care of my rig. Most times I cruise in 7th over or 8th direct when loaded. Just cause its there don't mean you have to use it. BTW if you find a 16 series 13 speed for 1200.00 I would like to know where I will take two if they have any more just cause.
    fortycalglock Thanks this.
  6. macgyver1267
    20
    Thanks for reply guys, it helps to do research. Going to haul processed cotton in 2 weeks and gotta get this done. Found several 14 series around 1200 to 1400 but no 16.
  7. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    Actually, running that 13 in direct will also give you (slightly) better mileage, as you are now running direct thru the trans, less drag, (more drive line efficacy) also you tranny will run cooler in direct, less bearing surfaces in play.
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Whats the model number of the trans you have now? I assume its an over drive trans? You trans final ratio is either .73, .80 or .86. most likely .73 but you would need the trans model number to be sure. A 13 has a final ratio of .73 and a 8Low ratio of .86. If your top gear now is .73 the top in a 13 will be the same. If your top now is .86, 8Low will be the same and 8high will give you extra speed. If your current top is .80 the 13 doesnt have a matching gear so you will need to adjust your driving to accomedate the new trans. Either way it will work. To really answer this, we need to know your current trans model.
  9. macgyver1267
    20
    Might have to go with 10 speed for now. ..
  10. macgyver1267
    20
    Will have to get under it to see model #. I know in 9th at apx 1500 i'm doing 65 on gps.
  11. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    You most likely have a direct drive transmission. The model number should be on the laminated printout in the dash. For the life of me, I can't remember the exact location. Glovebox maybe. It's been 8 years since I owned a truck with that dash.
