13 speed fuel milage
Discussion in 'Freightliner Forum' started by ROADDOGG63, Sep 22, 2014.
  1. ROADDOGG63
    ROADDOGG63 Bobtail Member
    What would the best rear end ratio to have for fuel milage. With DD15 13speed 22.5 low pro's like to run about 62mph at 1300 rpm
  3. bad-luck
    bad-luck Road Train Member
    3,458
    6,381
    Nov 16, 2013
    Baltimore, Maryland
    3.42 will put you around there
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Eaton has a calculator for this.....
    http://www.eaton.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf
    We need to now the revolutions per mile of your tire t be 100% sure. Assuming your trans is a double over and not a single over you should be good with a 3.36 rear. .73 is the final drive of a 13 with double over right?
    My recommendation would be to go with a 2.64 rear. Start out in low insted of first. To cruise at 57, you can be in dirrect gear saving fuel and transmission losses. When you need to go faster you have 2 more gears available and you can fly.
