13 speed splitter problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by zeljkorikverc, Mar 30, 2020.
  1. wore out
    wore out Numbered Classic
    17,470
    217,960
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    #### near every 7 and 9 series 13 speed on the road has this same problem....
    spsauerland Thanks this.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,575
    9,940
    Mar 30, 2014
    I realize the shift pattern says to preselect splits, I never have and i don't have this problem.
    Of course the manual says to use the clutch too, but that doesn't stop most drivers from not using the clutch.
    speedyk, wore out and swaan Thank this.
  4. wore out
    17,470
    217,960
    Jun 5, 2013
    I shift mine like you do...only time I have a problem is when I forget lol
    Bean Jr. and swaan Thank this.
  5. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    The trick is to tap the clutch like your supposed to. I shift like these guys also ^^^^^^^^^. Never have a problem.
    wore out and Bean Jr. Thank this.
  6. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    i had the same issue on a ten speed and it was the synchros so yeah i think it would have to be torn apart and looked at
  7. Bean Jr.
    5,575
    9,940
    Mar 30, 2014
    Regular or super 10?
    wtokhi Thanks this.
  8. wtokhi
    251
    115
    Nov 3, 2017
    regular ten, meritor
  9. Bean Jr.
    5,575
    9,940
    Mar 30, 2014
    Then it shouldn't have the same problem. Maybe same symptoms. On both Meritor and Eatons there is an interlock that prevents the range from shifting while in gear. Splitter preselect, the only thing that is preventing the shift is the load that is on the gears themselves. Remove it by backing off or clutching, the shift happens. That is why I don't preselect splits
    wore out and speedyk Thank this.
