13 speed stuck in high range
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rydr, Jun 27, 2021.
  1. rydr
    rydr Light Load Member
    123
    92
    Jan 8, 2019
    2001 w900 stuck in high range, where do I start? I dont think its anything mechanical as the transmission shifts fine and doesn't make any noise while driving. Sometimes I can get it out of high range but it will just get stuck in neutral, it never goes into lo range, but I can flip the selector up and hear it click into high range. I have a load to deliver Tuesday, dont think thats happening now.
  3. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Check your air lines on the trans one may be blocked pinched or cut
    Or if you recently had it worked on, they may have hooked up the lines wrong
    Or if your truck throws a lot of oil, the valve may be sticking
    Hulld Thanks this.
  4. FLHT
    FLHT Road Train Member
    1,438
    2,576
    Aug 2, 2014
    What kind of transmission ?
    Worn shifting forks ?
  5. AModelCat
    165,039
    If the air side checks out ok it may be internal. A broken synchro pin can keep it stuck in 1 range.
    Dino soar, wore out and BoxCarKidd Thank this.
  6. rydr
    123
    92
    Jan 8, 2019
    The transmission was rebuilt then the truck sat for 3 or 4 years. Pulled it out of the parts truck and has been in this truck for about 6 months
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    You have two rubber lines to the piston housing on the top right of the transmission. Mark them. You should have air out of one in high and the other in low with about 60 PSI. If OK take the back cover off that piston. It should not be dry and rusty.
    Dino soar and spsauerland Thank this.
  8. rydr
    123
    92
    Jan 8, 2019
    I took the plunger out of the housing not rusted, the o rings looked fine not torn or missing. I put air to the housing with an air gun, I can hear it going to low and high range. Took it for a drive and it went into low range once, but at the next stop sign it got stuck in neutral and was only able to get into high range. Does this seem like a weak air valve?
  9. AModelCat
    165,039
    Wonder if the air regulator on the transmission is failing. Transmissions run at something like 70 PSI.
    Dino soar Thanks this.
  10. rydr
    123
    92
    Jan 8, 2019
    I used shop air at 120psi. I think im going to replace the slave and splitter valve tomorrow. Everything is closed around me today
  11. BoxCarKidd
    4,555
    6,643
    Aug 26, 2014
    Check pressure to the active hose when it will will not shift. Sounds like broken pins as AModel mentioned.
    That other stuff is just throwing money at it if you do not do tests.
    spsauerland Thanks this.
