13 Speed Tranny complete STOP
Discussion in 'Ask An Owner Operator' started by DetroitSpecial, May 10, 2015.
  1. DetroitSpecial
    DetroitSpecial Light Load Member
    76
    31
    Mar 18, 2015
    13 speed upside down H pattern it goes like this
    R 1 4
    L 2 3 LOW SIDE
    5 8
    6 7 HIGH SIDE
    Flip side switch FORWARD & you have 13 Speed
    but when you are on the High side and have it wide open running you flip the dog Forward and it automatically rolls to 13 speed,Once you go to slow down and if your on the high side,you can not shift on the low side once the dog is flipped forward,
    you have to come to a complete stop,and start shifting your way back up from low side again,i mean a complete stop so, i only use the 13 speed when im on a stretch of highway,but if im local in a city or in alot of traffic i only use it up to 8th gear.
    Heres my question to the old timers and mechanics,what other ways can you slow down or split this tranny to go to the low side if possible with out starting over and coming to a complete stop?
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Flip the button back, let off the throttle, give it throttle again and it will shift back into the lower side and then you can shift down into the lower gears. At least that is how mine works.
    double yellow Thanks this.
  4. IH Truck Guy
    4,946
    57,438
    Mar 2, 2008
    Purgatory
  5. DetroitSpecial
    76
    31
    Mar 18, 2015
    Hmmm, ok i definitely try that,so when you shift out of 8 th and go to 13 gear do you flip the switch get off then back on throttle and it goes to 13 also like mines? What type of truck you run and what year?
    Mines in the pic above
  6. Hammer166
    7,605
    27,793
    Aug 18, 2007
    ~8600+' and loving it!
    Wow, how old a truck is that? Is it RTOO, or an RTLO without the x-pattern shift tower?
  7. DetroitSpecial
    76
    31
    Mar 18, 2015
    Lmao,naw its a 95 International i bought it from a old guy who completely changed some things up, my mechanic said he never saw a international with a 12.7 detroit 60 series in it lol plus i dont think its a eaton fuller i believe its a Spicer lol
  8. cnsper
    5,869
    27,421
    Feb 28, 2014
    I have a 94 KW with an 18 speed Eaton and a 2002 KW with a 13 speed Eaton. I have also driven a 2001 Western Star with a 13 speed Eaton
  9. DetroitSpecial
    76
    31
    Mar 18, 2015
    Your 13 speed is like mines as far as shift pattern? or is it like the super 10, i have seen alot of people split the gears like a super 10 but not a 13 speed, they split 18 and 15
  10. OLDSKOOLERnWV
    19,141
    289,418
    Do you split shift the button on the side at all?? You have 2 buttons correct?
  11. DetroitSpecial
    76
    31
    Mar 18, 2015
    Correct i have the high and low side separator in the middle of shift like a normal stick does, then theres the side switch on the left side of the stick and thats what you flip when you are on the high side that takes i from 8th gear to 13
