13spd vs 15spd transmission?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ErieMcDreary, Nov 3, 2020.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    394
    Dec 4, 2016
    Erie PA
    I now have a 10 spd which I hate, I considered going to a 13spd, but that costs too much, due to all the changes, (trans cost, bell housing different, drive shaft length, etc.).
    I think that a 13spd is basically a 9 spd where you split the high side 4 gears, is a 15 spd basically a 10 spd where you split the high side 5 gears? Does that mean it would be a more cost effective swap, where in I could use the same bell housing, drive shaft, etc?
    Truck is a Volvo, D13, Eaton trans.
    Looking more at when/if trans need rebuilt, rather than just swapping it for no reason.
    Thanks.
  3. 201
    201 Road Train Member
    12,787
    26,314
    Apr 16, 2014
    high plains colorado
    Hate a 10 speed? With todays power, a 10 speed should be all you need. I've had 13's that wouldn't split when cold, or worn. I'd say 75% of the trucks I drove had 10 speeds, and I never remember a problem. I'd leave it alone.
  4. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    15 spd you split the low range.
    Not much use unless you run heavy.
    I shift mine like a 10 spd
    Don't use the low low range
    magoo68, Roger McG, Bean Jr. and 4 others Thank this.
  5. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    If you don’t like a 10 you will not like a 15. Nothing to gain above 20 mph.
  6. bjrc
    bjrc Light Load Member
    81
    97
    Sep 14, 2018
    A 15 speed splits the low side gears, actually gives you two more low gears so really has 12 forward and 3 reverse but they are one of the tougher transmissions. Basically a 10 speed with a back box.
    Rideandrepair Thanks this.
  7. Cat sdp
    Cat sdp . .
    21,308
    76,229
    Apr 8, 2012
    Orion's Belt
    If your gonna spend the money just get a 18 and be done with it.....
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    @ErieMcDreary how much was the quote for the 13speed swap?
    I am considering doing the 10speed to 13speed. My tr
  9. okiedokie
    okiedokie Road Train Member
    13,885
    110,020
    Jun 13, 2011
    PNWET
    I'm confused. You split a 15? It's 3 ranges. DR, Low & High. You can shift DR to Low but not Low to DR on the roll.
  10. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    ^^^^^^^^^^^^ Right here^
    Had a 15 sp direct. Gained 1 maybe two gears( i forget) below the ten. When needed shifted the five lo-lo range gears as needed. When ready shifted from lo-lo range gear to the next gear lower in low range and be ratio correct(?). Example, go from 5th lo-lo to 4th lo.
    Had a RT direct trans.Maybe the overdrive tranny's are different?
    Now have an 18 sp and a very happy with it.
    Take a look at Roadranger site. It will tell all.
  11. Rideandrepair
    17,562
    56,901
    Aug 8, 2015
    A 10 speed is kind of hard to beat, as far as price and durability. Depending on how much torque you have, you may end up dropping whole gears even with a 13 spd.
