14 cascadia loses gauges no codes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 77fib77, Sep 26, 2022.
  1. 77fib77
    77fib77 Road Train Member
    11,692
    77,204
    Jul 7, 2010
    St Louis
    I have a dd15 cascadia 564k miles. I have a scan gauge it will go blank and the spedometer tachometer drop a bit then it powers right back up. Normal gauge drops 10 15 mph. I have changed master power switch, ignition switch, pndb, starter. All battery nuts are tight.
    It will do this on flat ground or going up a hill. No codes. Head lights stay on. It dies it a couple of times in 4 to 8 hours. Today it did it twice back to back. 15 seconds apart. I thought that was it. Then it ran good for another hour until I'm parked.
    Is it the cpc 4 module?
  3. johnb!
    johnb! Bobtail Member
    Nov 2, 2020
    its most likely you main fuse box that's under the glove box. I had the same issue with mine, gauges would die or they wouldn't sweep when you turned the key on sometimes.
    LoneRanger Thanks this.
  4. LoneRanger
    LoneRanger Road Train Member
    3,696
    9,609
    Jun 3, 2018
    Possibly a loose fuse, bad fuse, or bad connector on that slot. fuse box is in glove box.
  5. 77fib77
    11,692
    77,204
    Jul 7, 2010
    St Louis
    I got it scanned again. Cpc4 codes came up. So I'm going to get it reballed and then figure out what to do.
  6. LoneRanger
    3,696
    9,609
    Jun 3, 2018
    What year?
  7. 77fib77
    11,692
    77,204
    Jul 7, 2010
    St Louis
  8. LoneRanger
    3,696
    9,609
    Jun 3, 2018
    Check the fuse before you take it in. Could save you hours of diagnostics and money if its not needed.
    77fib77 Thanks this.
  9. IH9300SBA
    IH9300SBA Road Train Member
    2,432
    24,001
    Feb 26, 2021
    Does it have the maxi-fuses located under cab below drivers door? Check for corrosion there as well. I don't recall what year they moved them, but something to look for.
  10. 77fib77
    11,692
    77,204
    Jul 7, 2010
    St Louis
    Like on the pndb? Those are some fuses. I only checked the fuses on the fire wall in the engine bay. I already dropped off the CPC4 to get reballed so it's kind of there already.
    IH9300SBA Thanks this.
