14 speed transmission?
Discussion in 'Freightliner Forum' started by 04 LowMax, Dec 1, 2022.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    First time driving an autoshift in 49 years of trucking. Gotten used to how to work with it. What I cannot figure out is how it has 14 gears. 1-13 plus a low. I've never encountered such a thing. How would you get 14 gears if it was manual? Maybe a 13 plus an air selected low range? This is a new one on me.
  3. AlexR_uz
    AlexR_uz Bobtail Member
    19
    14
    Sep 10, 2019
    PA
    12 forward and 2 back.
    nredfor88 Thanks this.
  4. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Nope. It's got 14 forward and 2 back.
  5. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,935
    Apr 2, 2021
    TARHEEL
    Post #3 = :confused::eek:o_O:oops:
  6. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    You don't usually count reverse. EG 18 speed=18 fwd gears, 13 speed = 13 fwd and so on. This thing has 14 fwd. Just thought I'd see if anybody was familiar with this trans.
  7. Jubal Early Times
    3,069
    20,582
    Oct 17, 2022
    I’m not familiar with it but years ago spicer had a 14 speed. They also had a 20 speed. A 7 speed main with an air shift hi-lo would give you 14 speeds
    04 LowMax Thanks this.
  8. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    This one has L, plus 1-5, then it does a range shift goes to 6, and sounds like it splits the top end, like a 13.
    Jubal Early Times Thanks this.
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,480
    9,717
    Mar 30, 2014
    Really a 13 speed is a 14 speed. Low in the high range is redundant of 4th in the lo range, so we don't use it. But if you did, you could split it giving you 14.
  10. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Yes, I used to use that gear sometimes going around a corner, saved going into low range. Just had a bigger rpm split than going down to low range. Anyway, regarding this 14 speed transmission, I've given up finding info on it. The truck was built in Mexico but can't find a model # of the trans. But it's definitely got 13 speeds, plus a low gear. I'm just going to drive it and not analyze it further. I will say, the autoshift is nice in the city but I sure wouldn't want to take it off road, back into the bush and icy hills. Even an old Mack with a 6 speed would be better there. Thanks to all who replied. I'm done on this one.
    Bean Jr. Thanks this.
  11. Bean Jr.
    5,480
    9,717
    Mar 30, 2014
    Perhaps this is not a popular thing to say. I like shifting. When do you need to shift? It isn't going down the road at highway speeds, rather in city traffic. I simply would hate an automatic in traffic!
    singlescrewshaker Thanks this.
