15 FL dd15
Discussion in 'Freightliner Forum' started by Keepontrucking2016, Oct 24, 2019.
  1. Keepontrucking2016
    Keepontrucking2016 Light Load Member
    170
    40
    Apr 7, 2016
    Does anyone know what this problem is and my rpm goes up and down a bit
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I don't see rpm goes up and down...
    but I hear something...
    AModelCat Thanks this.
  4. AModelCat
    164,724
    Tach looks pretty steady to me. Not something I'd worry about.
    I too hear something though. Sounds like an exhaust leak. Maybe a miss? Kinda hard to tell.
    mhyn Thanks this.
  5. Keepontrucking2016
    170
    40
    Apr 7, 2016
    here is a longer video it's hard to see on video rmp go up n down
  6. Keepontrucking2016
    170
    40
    Apr 7, 2016
    I forgot to mention once the engine warms up you can barely hear it n it plus does it a bit when im loaded climbing hill
  7. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    nothing wrong with rpm. the gauge is not accurate plus there can be little up and down of rpm. its acceptable. do valve adjustment and use good fuel.
  8. Keepontrucking2016
    170
    40
    Apr 7, 2016
    I did valve adjustment about a year ago truck Has now 581k miles maybe I need to do it again. when I drive for a while my oil psi stays at around 19 20psi then slowly goes up to psi to 29 30 is that normal
  9. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Sounds like a stuck open exhaust valve. Take rocker cover off and inspect valve lash.
  10. Keepontrucking2016
    170
    40
    Apr 7, 2016
    I'm sorry I'm still learning where is that at
  11. SoCalRed
    SoCalRed Medium Load Member
    437
    851
    Feb 7, 2017
    CA
    If you don’t know where the valve cover is do not attempt to work on your truck. Take it to a mechanic.
    mhyn and QUALITYTRUCK Thank this.
