15 speed double OD
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stroked F550, Nov 9, 2009.
Page 1 of 4
Low Range
R 2 3
1 4 5
All bottom gears can be split
High Range
R 7 8
6 9 10
High range can't be split.
This was the shift pattern of the 15 speed I had years ago.Stroked F550 Thanks this. -
thanks pulling trucker
I heard something about the 15s having an X pattern was that way before 96? -
The pattern I gave you was out of my Pete, but I can't remember if it was a double over or the year. Short term memory loss due to the fact it was a company ride.
well hopefully its the same pattern that you mentioned
The 15 I drove did not split the lower gears, it was a double reduction in the lower 5. You could go from the reduction gears (1-5) and hit the spliter to go to 4th, then continue on up the high side.
I drove a 97 379 that had the same shift pattern. I didn't use the double reduction gears unless I was loaded heavy and starting out on a hill.1989 Pete Thanks this. -
That's a good tranny I have one!.what DO YOU HAUL?
cars mostly but I am going to start hauling equipment and freight on my step deck
Never saw a 15 shift like that, mine was just like a 10 speed. on the newer one, RTX. the old one the last two holes were reversed (4@5 holes) RTO. 5th, 10th, and 15 were against the dash. the lower 5 gears were like LB say's, but you can go from 3 to six or a couple of ways
Page 1 of 4
