16 ply vs 14 ply on steers
Discussion in 'Ask An Owner Operator' started by 4wayflashers, Apr 1, 2023.
  1. 4wayflashers
    4wayflashers Road Train Member
    1,080
    1,246
    Mar 14, 2014
    Im not trying to recreate the wheel. Just getting some good steers probably Cont ecoplus hs3s. But when it comes to the extra plys I get it you can run higher pressure but what are the drawbacks?
    I got 140,000 out of my Good YearEndurance LHSs so I dont want to push them too hard coming into summer.
    Thanks
  3. Big Road Skateboard
    7,606
    43,838
    May 2, 2021
    I usually do 16 ply. They aren't going to run much higher pressure though.
    Higher load rating, and more durable.
    Drawbacks, rougher riding.
  4. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    I’ve heard they are the same tire with just different markings in the sidewall. Who really knows.
    4wayflashers Thanks this.
  5. 4wayflashers
    1,080
    1,246
    Mar 14, 2014
    Do they run louder in your experience?
    I’ll probably go with 14 if is smoother ride.
  6. 4wayflashers
    1,080
    1,246
    Mar 14, 2014
    My sun visor says Front axle WT 10,483 so not too heavy for 14 ply
  7. rollin coal
    rollin coal Road Train Member
    13,889
    28,888
    Mar 29, 2008
    TN
    I always ran 16 ply steers on everything. I figured because they're steer tires they carry more weight and take more abuse than the other 16 tires so why not. Up front cost wise not that much difference between them and 14's. Hard to imagine much difference in ride quality these are semi truck tires after all.
    Vampire, Magoo1968, D.Tibbitt and 2 others Thank this.
  8. Big Road Skateboard
    7,606
    43,838
    May 2, 2021
    No, they'll sound the same. I think 14 ply is fine for most OTR applications.
    Yeah, I don't have much personal experience there, so my mentioning that is coming from what customers have told me. I've only driven 2 years, and only ran 16's all the way around
    Vampire and 4wayflashers Thank this.
  9. rollin coal
    13,889
    28,888
    Mar 29, 2008
    TN
    You won't get any more load rating just by installing 16 ply. I think both of my last trucks axles were 12.5k which 16 ply is overkill for those too but I always ran them anyway.
  10. rollin coal
    13,889
    28,888
    Mar 29, 2008
    TN
    Maybe a little stiffer sidewall. I've driven trucks in the past that had 14 ply steers. Honestly if you or I hopped in 1 truck with 14's and another with 16's doubtful we'd even be able to tell the difference. It's like the guys who "check their tire pressure" with a tire thumper. You can't tell jack **** about the air pressure in a tire unless you actually stick it. But they'll swear oh yeah I can tell how much air is in it by whacking it with a thumper.
    Vampire, D.Tibbitt, Siinman and 3 others Thank this.
  11. 4wayflashers
    1,080
    1,246
    Mar 14, 2014
    If I could find a good reliable digital tire pressure checker I would
