18 speed vs 15 speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dusty Boots, Sep 16, 2015.
  1. Dusty Boots
    Dusty Boots Bobtail Member
    29
    Jul 16, 2013
    Alberta, Canada
    Hey fellas, looking at a truck that is spec'd exactly the way I want (1999 550 cat, 3.70, 24.5 rubber, so that would get at about 105kmh in top gear which is what I'd like), has everything I'd be looking for in a truck except that it has a 15 speed tranny, I was hoping for an 18. I've never driven a 15 speed so for those that have driven both would I regret going with the 15 or should I hold out for an 18. I'll be pulling super B grain trains loaded up to 140k and sometimes coming out of soft fields. Additionally, I checked Eaton's website and they say their 15 is only rated up to 1650 torque, that 550 cat is 1850. Now I've heard that 15s are pretty tough trannys but would this worry anyone? I like the idea of not having an air actuated split, but would it handle what I'd want to throw at it? Thanks for any help fellas, it's much appreciated.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If the truck is what you want then go for it.
    I got a 15 in one of my gliders behind a 550 E model with 600/2050 file in the ecm.
    I wouldn't be worried about the trans not taking the abuse , there perty stout.
    Some times it would be nice to split the top gears but overall it works well.
    If your still not happy a trans swap to a 18 is no big deal really.
    Dusty Boots Thanks this.
  4. Dusty Boots
    29
    Jul 16, 2013
    Alberta, Canada
    Yeah true enough. With an 18, 24.5, and 3.70's it might be a little fast, I guess I could throw 22.5's on as well. What does a nice refurb 18 go for here in Canada?
  5. granhawler
    granhawler Light Load Member
    296
    56
    Feb 26, 2011
    My first truck had a 15 double overdrive in it & it was bullet proof pulling a hopper bottom @ 100,000lbs. My last truck had a 13 & my current truck has an 18. Maybe its because it was the trans. I learned to drive on but I'm still partial to a 15, I like the deep reduction too for pulling out of soft fields.
  6. FinkPloyd
    FinkPloyd Light Load Member
    206
    268
    Sep 2, 2015
    My Fathers Old Freightliner Flc had a 15 speed behind a B model Cat.. You will love that Tranny if you ever have to go off Road.
  7. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    I just got done pulling OSOW daily up 155k, thru sand, dirt, mud,like this-
    and (occasionally) hardtop with a 15, and like Granhawler says, that deep reduction is nice to get out of the nasty stuff. I just wish when my boss added the 4th axle for HH, he would have upgraded the drive axles as well. The tranny has held up fine for over 2 years now; however we're on our third one of these....
    :cool:
  8. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    15 speed for offroad,18 for on road as you can split the gears.
  9. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    No bid deal but you didn't say if its a 15OD or 15 direct. I'm not sure what the advantage of the deep reduction is....IIRC there isn't much if any difference in the ratios from the 15 and 18....1st gear might be a tich lower in the 15. Personally, I HATE the 300+ rpm steps between the gears on the 15OD. 15 is probably a more durable trans because of those syncros in the 18.
    Last year, Domar in Toronto quoted me $5,000 + my 15OD as a core. Then you'll need to add your mechanic's labour.
  10. Dusty Boots
    29
    Jul 16, 2013
    Alberta, Canada
    Cool pics man, I haul machines now with an 18 (truck's not mine though). How is it shifting from deep reduction to low range? I'm pretty sure bull low on an 18 is a little lower than 1st(deep reduction) on a 15, but unless I get it perfect I usually get a little tickle going from bull low to 1st.
  11. Dusty Boots
    29
    Jul 16, 2013
    Alberta, Canada
    Thanks for the replies fellas, the tranny in questions was a 15OD.
