1983 W900 Dash problems
Discussion in 'Kenworth Forum' started by mclow, Aug 17, 2014.
  1. mclow
    mclow Bobtail Member
    4
    Mar 26, 2012
    Bloomfield, NM
    I have a 1983 W900 and I have a very annoying thump somewhere around the dash. When I hit a bump it sounds like a midget is under my truck with a 10lb deadblow smacking the floorboard, or around the firewall area. I have taken all of the gauge access panels out and have found nothing that looks loose or out of the ordinary. the dash has a little play and I think this is the problem. Has anyone had this issue and what did you do to fix it. ANNOYED
  3. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    It may not be the instrument cluster, I would check under the hood and along the firewall, also would check the cab mounts, battery hold downs, thing of that nature. Sounds like that can be very frustrating as they transmit through the cab and chassis. :biggrin_2556:
  4. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    Check your front leaf spring bushings.
  5. 201
    201 Road Train Member
    12,826
    26,411
    Apr 16, 2014
    high plains colorado
    Probably the hood. Check for shiny spots where the hood meets the cowl and check the rubber bumper pads that support the hood.. I've had doors rattle too. Could be spring hangers, but I think you'd feel it in the steering wheel. Like Alaska says, that Ka-knocking can be transmitted through the cab from somewhere else. Close the hood on a wadded up rag, and see if it still makes noise.
  6. w9l
    w9l Medium Load Member
    316
    514
    Oct 12, 2013
    My W900L experience -which I have about 18yrs of- says Semi-Retired probably hit the nail in the head. When dash itself is loose you can carefully snug screws forward near glass and help that, but at worst it generally just creates an anoying squeak when you hit a bump. When front cab supports wear/flatten out the cab will slightly nosedive which allows the hood to bump cab. I replaced my hinge mount bushings and that raised the front of hood up considerably more than I would have thought. Had to adjust hood forward as far as it would go to keep it from bumping. Also cut out some rubber donuts and dropped them over the rubber guids back by air cleaners because it was binding when you first tried to get it started coming up- kinda stuck closed. None of it made any sense to me until I had the sleeper off and changed those bushings back there. Went to put boot replacement boot in and it was alot tighter at top than bottom. Had stacks off so I got out and compared the gap between bunk and cab. That is when I figured it out. Gap was about 3/4" wider at top than bottom. Replaced front bushings under cab. Problem solved, except I need to move hood back just a fuzz. It opens much easier and sets on the cowl like it si supposed to now. Funny thing is I never replaced rear bushings under cab because dealer was going to have to order them and I didn't have time. Everything seems to line up good as is. If you decide you want to change the front ones, let me know and I will give you detailed instructions. Sorta a trick or combination to doing it with cab still on truck. No big deal. Like 18 bucks a side at kw for bushings.
    Tilt column U joints are another annoying thump, but u can feel it in wheel. Changed underhood u joints twice before I figured out the main problem there was - the joint in the column itself.
    "semi" retired Thanks this.
  7. Alberta-Mechanic
    Alberta-Mechanic Light Load Member
    What type of engine and year check flash codes than google code to find problem I suggest registering on cummins quick serve online it is free and it will take your engine serial number and than you have all manuals for free!!!! there are several ways now a days to get flash codes if you have an info center on the cluster there a control on right side of sterring wheel on the column. if not look for a switch labeled DIAG this will flash out codes via check engine light . Or put cruise switch on and use accl/decl switch to flash out code. count the blinks this is your fault.
    The fault code will flash in the following sequence:
    First, a WARNING (yellow) light will flash . Then there will be a short 1- or 2-second pause after which the number of the recorded fault code will flash in (red) STOP. There will be a 1- or 2-second pause between each number. When the number has finished flash ing in red, a yellow light will appear again. The three-digit code will repeat in the same sequence.
    The lights will continue to flash the same code until the system is told to do something else. To go to the next fault code , move the cruise control/PTO switch momentarily to the RESUME/ACCEL position. You can go back to the previous fault code by momentarily moving the cruise control/PTO switch to the SET/COAST position. If only one active fault is recorded, the system will continuously display the same fault code when either the RESUME/ACCEL or SET/COAST switch is depressed.
  8. Alberta-Mechanic
    Sorry wrong page all use full info though. I'd check the dash inbetween window like w91 allready suggested
  9. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    shock mounts and front cab mounts would be my first check.
  10. mclow
    4
    Mar 26, 2012
    Bloomfield, NM
    I did end up figuring it out. The hood locators were misadjusted and I spaced them out and replace rubber seal around the cab where the hood comes in contact with it and it fixed the problem. Thanks for all of your replies
    rollin coal and Alaska76 Thank this.
  11. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Excellent, thanks for the update!
