1987 Ford L9000 Big Cam overheating under load
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by gravytrain416, Feb 15, 2018.
  1. gravytrain416
    gravytrain416 Bobtail Member
    17
    7
    Feb 21, 2015
    We recently purchased a 1987 L9000 single axle daycab as a backup tractor for our semitrailer repair business. It has a Big Cam Cummins 855. The truck sat a lot before we purchased it. Only 7,000 miles have been put on it in the past 5 years. This afternoon, I hooked up to a J.B. Hunt container to deliver it. After about 4 miles, the temperature started creeping up. Temperature light came on before I was able to get it pulled off on the shoulder of an off-ramp. Called our road service guy (who fortunately was at the shop at the time). He brought some water and coolant out to me. By this time, the engine had cooled off pretty much. We found that it had been puking coolant out of the overflow tube. We filled the radiator back up, and got on the flip, and brought it back to the shop. Under a load, getting back onto I-85, the temperature slowly started to creep up. By the time I got to the exit (just a mile), the light came back on. As I let off of the throttle, and got the RPMs back down, the temp went back down, and stayed around 175 until I got back to the shop (just a couple miles).
    Two questions: first, what is the difference between the Big Cam III and the Big Cam IV, and how can I tell which one I have? Engine tag says NTC-315. I've mostly driven trucks with Detroits in the past; don't have a lot of experience with older Cummins engines. And second, what could be the culprit for the overheating? I've read a few things on the internet about some of the Big Cam engines having an overheating problem. Since the truck has sat for so many years with little use, we wondered about a sticking thermostat. It would be nice if it were that simple. But I don't know. Didn't mess with it after I got the trailer back to the shop this afternoon. It was quitting time by then.
    We only gave $3500 for the truck, with 794K miles on it. It's in pretty decent shape other than this little issue. Any input will be greatly appreciated.
    Oldironfan Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,580
    6,675
    Aug 26, 2014
    That is a big cam 4 with low flow cooling. Cannot see the radiator hoses in the picture but they are only about 1 1/4 inch hoses.
    Start in the normal way. Inspect belts, fan clutch, dirty radiator and bottle test. The next place I would go is a pressure gauge in the block at the right rear maybe six inches below the exhaust manifold. You are looking for about 50-52 PSI at rated speed. If you do not have that the water pump belt or impeller is probably slipping.
    They had some thermostat changes and Cummins remachined the housings on some of those. I always take the old ones out and get the numbers off of them. Not knowing the trucks history this could be a problem and I don't remember how to check that. There should also be a cone shaped screen in a hose above the thermostat housings, check that.
    Low flow radiators have smaller than normal tubes in the radiator which are not very tolerant of stop leak. They also have some check valves in them that can cause problems. Check for odd temperatures through the system with a heat gun.
  4. 062
    062 Road Train Member
    6,370
    34,110
    Oct 20, 2013
    Also make sure the radiator Itself isn't stopped up,use your favorite degreaser and pressure washer,just don't bend the fins.
    gravytrain416 Thanks this.
  5. BoxCarKidd
    4,580
    6,675
    Aug 26, 2014
    Or is it? How big are your radiator hoses?
  6. gravytrain416
    17
    7
    Feb 21, 2015
    That's a lot of information, and I sincerely appreciate it. It gave me something to go on. One of our trailer mechanics used to be a diesel mechanic before he came to work for us. He said something this afternoon about doing a pressure test as well. He also mentioned 'stop-leak' and said that he had one of those engines in the shop one time where the customer had used it, and it totally screwed up his cooling system. And like you mentioned, it does have some very small hoses. I noticed there was a little slack in the belts, not too much, but more than it should be. I guess it could be something as simple as that.
    Thank you again. I really do appreciate your help.
  7. gravytrain416
    17
    7
    Feb 21, 2015
    We'll check that for sure. Thank you.
  8. 062
    6,370
    34,110
    Oct 20, 2013
    What rpm were you running at? Those motors will heat up pretty quick if you lug them. 1600-1700 is about as low as I'd go on even a little pull.
    gravytrain416 and BoxCarKidd Thank this.
  9. gravytrain416
    17
    7
    Feb 21, 2015
    I was running the interstate about 2000 or so, 65 mph (it's geared pretty low).
  10. BoxCarKidd
    4,580
    6,675
    Aug 26, 2014
    They were made when the speed limit was 55. If you mash it to the floor and hear a faint belt squeal I would almost bet a paycheck it is just the loose belt. It does not take mush and check the idler for play.
    Nothing to do with your problem but you might find this interesting. When I worked at a fleet that purchased BC4 315's a Cummins Rep came and gave a class on the low flow cooling system. One of the guys asked why we are backing up from 350's to 315's. He put it all out with graphs, charts and figures. The 315 produced more torque and HP over a broader range than the 350. While the 350 will produce more torque and HP is was only in a small RPM range. Day in and day out the 315 will out preform it and get better mileage.
    I don't totally buy that but they did better than ever expected.
  11. gravytrain416
    17
    7
    Feb 21, 2015
    That's really interesting. The thought was in the back of my mind, that yes, it's a 31 year old truck, and we didn't have those high speed limits back then. We're going to get it totally gone over, full service, belts and hoses and the whole nine yards. You're probably right. Nice to have experienced folks like you for advice!
    That's interesting about the 315 vs. 350. I'm 41, so I wasn't driving back in the day when these engines were more widely used. I got my start with Burlington Industries when I was 24, back in 2001. I always liked the 60 series Detroits myself. I was born too late to drive in the good old days. But I love the older trucks.
    Only other question I had is what was the difference between the Big Cam III and IV?
    Thanks again for all your information and help. I really do appreciate it. I've taken notes of all you said. We'll get this old girl right. I like keeping old equipment alive. Past my bedtime.
    x1Heavy Thanks this.
