1992 Pete 379 AC
Discussion in 'Peterbilt Forum' started by Thundercat81, Aug 8, 2021.
  1. Thundercat81
    Thundercat81 Bobtail Member
    5
    Does anybody understand how the air pressure in the cab works, ill cruise around for a couple of hours and my ac will drop in pressure another words the air flow. I assume its got a flap inside because hear it open. After a while the fan motor is running but no air comes out...Anybody got any advise ?
  3. PSM379
    PSM379 Heavy Load Member
    951
    3,972
    Apr 19, 2019
    Evaporator is freezing up.
    Roger McG and God prefers Diesels Thank this.
  4. Thundercat81
    5
    Nope everything is running properly under the hood. Its all new. You can barely feel the air come out at random times . but it comes out cold that's for sure. Is there a flap in the chamber under the dash controlled by air. I feel the that might be the problem. i opened the glove box and the fan motor was running full blast but very little came out..
  5. cke
    cke Road Train Member
    6,158
    75,794
    Aug 4, 2013
    Colfax Wi
    Fan motor might be running full blast but is the fan turning?? Squirrel cage may be spinning on the shaft.
  6. Thundercat81
    5
    yup got buff rat with a large piece of cheese. Its new motor too
  7. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Is it a slow stop to the air flow or fast? Does it come back the same as it goes away?
  8. Rideandrepair
    17,557
    56,881
    Aug 8, 2015
    The doors closing. Probably needs a new air piston actuator. Though it usually comes out somewhere, defroster vents or floor vents. Try those settings. Not familiar with Petes. Most Trucks have about 4 different air piston actuators that control different blend doors. Tiny 1/4” airlines from each running to dash control. Schematic from Dealer helps. Take the bottom panels off, start looking and following the air lines. Each ones usually a different color, white black yellow blue red etc. My Freightliner has 4 of them. 1 is on the top, has 2 air lines running to it. The others are accessible from the bottom. Usually if ones bad, it’s cracked or o rings leaking. You’ll hear it leaking air in the dash, when adjusting the controller. Could be the controller on dash. Again usually hear it leaking air.
    God prefers Diesels Thanks this.
  9. Thundercat81
    5
    thanks appreciate it
  10. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    This is a symptom of the evaporator being frozen up, try setting to heat or vent (blower running, ac off), id wager that in about 10 minutes you have full air flow back. That would mean your freeze control switch isnt working. It will do this worse and faster in more humid conditions.
    Costs you no money to troubleshoot that.
    Roger McG, PSM379 and lester Thank this.
  11. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    I know most of the Pete's I've worked on have electric actuators for the blends doors, not air cylinders like a freightliner. 92 could be different but would be easy to hear if you move the dial with truck not running
    Rideandrepair Thanks this.
