1993 kenworth brake issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Moparjoe, Apr 12, 2017.
  1. Moparjoe
    Moparjoe Light Load Member
    93
    30
    May 3, 2014
    Hey all. I have a 93 t800. Now a dump truck. Problem is the brakes are so touchy if you put 20psi pressure it locks up the rears. Ive adjusted them correctly. Says on dash equipped with a proportiining valve bla blh blah. Its scary barely touch the brake pedal and smoke show!! Any ideas
  3. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Check pressure to chambers compared to foot valve. The relay valve in back may be giving more than what you want from pedal
  4. Moparjoe
    93
    30
    May 3, 2014
    It has a bp-1 valve and its giving it full pressure. I mean if its empty i touch the pedal it locks the brakes up
  5. ClineER
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Did you bypass proportion valve? That valve reduces pressure to rear brakes. You dont need one for a dump truck. But the rear relay valve. COuld be sending say 80lbs instead if 20lbs like your asking for. If you hook up a gauge and compare pressures it will tell you if relay valve is bad.
  6. Moparjoe
    93
    30
    May 3, 2014
    No i havent bypassed it and it seems like its giving it alot of pressure. Dont know how to bypass it. My bp relay only has one sevice line to the top. Not sure whats going on i didnt build the truck. But when its empty its scary to hit the brakes fast.
  7. OLDSKOOLERnWV
    19,251
    291,188
    Peddle a little stiff at first, then brakes engage quick and hard?
  8. Moparjoe
    93
    30
    May 3, 2014
    No soon as you put your foot on it its lockin em up
    OLDSKOOLERnWV Thanks this.
