1994 3406e Cat Coolant
Discussion in 'Ask An Owner Operator' started by rslivelyjr, Apr 18, 2024.
  1. rslivelyjr
    rslivelyjr Bobtail Member
    39
    10
    Mar 14, 2023
    Ok can I bypass the low coolant sensor ? It’s a 4 wire sensor ? If not would it give me any problems if I just unplug it ? Also, my stop engine light comes on at 200F. Any suggestions on that? Thanks
  3. 062
    062 Road Train Member
    6,346
    34,006
    Oct 20, 2013
    You may have two temp sensors, one for the dash and the other for the ecm. It wouldn’t be a bad idea to confirm the engine temp with a infrared temp gun.
    @Big Road Skateboard may know of a way to bypass sensor.
    blairandgretchen Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    The gauge or sensor probably isn't accurate. Shut down is 225* for my 05 cat.
    My 05 I could unplug the radiator reservoir sensor. Top tank. It went bad and wouldn't let the engine stay running.
    Tug Toy Thanks this.
  5. wore out
    wore out Numbered Classic
    17,431
    216,943
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Take it to a shop with CAT diagnostic equipment have them plug it up and turn the low water sensor in the ecm.
    just to say it the low coolant sensor is always in the tank…..temp sensor is always in the head. I also don’t condone turning such features off in stead of fixing them even to get to a shop but to each their own
