1995 9200
Discussion in 'International Forum' started by chewy1973, Oct 1, 2016.
  1. chewy1973
    chewy1973 Bobtail Member
    i have an issue with my volt guage. it will only read 12.5 to 13 when you turn on the lights its drops but nothing goes dim or out. truck starts every time with no problems what is wrong.
  3. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Maybe a battery going bad. Load test them.
  4. thejackal
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Then do a voltage test on the alternator. See what the output is.
  5. thejackal
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    It also might be the voltage Guage in the truck is going bad.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    could be a ground wire, check where the wire is crimped at the alt. a cheap h.f. volt meter can be used to test volts everywhere.
  7. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    Could be bad gauge or resistance to gauge. Like heavyhauler said check voltage at the batteries and alternator. @Heavyd can probably tell you the spec. I don't like more than .5 volt between the two.
  8. AModelCat
    164,645
    Seen that issue on off highway equipment a few times. In my experience it was typically a loose ground cable.
  9. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Check all your cab powers and grounds. Something is dirty/loose somewhere.
