1995 peterbilt 379 3406e 1lw cutting out while accelerating
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dbrat62, Mar 2, 2025.
  1. dbrat62
    dbrat62 Bobtail Member
    Hi I am having trouble with my truck cutting out while accelerating 1lw 3406e 379 1995 peterbilt
  3. Diesel Dave
    9,781
    33,778
    Jan 20, 2010
    Hesperia, Ca.
    I replied on the older thread you revived
  4. 062
    062 Road Train Member
    6,351
    34,023
    Oct 20, 2013
    There’s a long list of things that it may be. It’s best to hook up to it with ET and see what codes it’s setting if any.
    For me it was the coolant temp harness rubbed behind the alternator,that never set a code.
    Bean Jr. Thanks this.
  5. Texasgordo
    Texasgordo Medium Load Member
    449
    1,703
    Sep 11, 2007
    Gonzales, Texas
    Could also be the throttle position sensor in the foot pedal going bad.
    Bean Jr. and PSM379 Thank this.
  6. lester
    2,958
    8,091
    Jan 2, 2012
    NW, Iowa
    do you have fuel pressure gauge? if not id start with changing fuel filters.. after that it could be a lot of things..
    Texasgordo Thanks this.
  7. Nine_Lives
    Nine_Lives Bobtail Member
    22
    20
    Apr 20, 2024
    Only while accelerating? Did this just start? How does the engine harness look from the swap? Does it smooth out if you're cruising? Any smoke from the stacks when doing this? Hard starting ever?
    With the cruise control switch off hold down the resume switch, this will flash codes on the check engine light. "55" is 'no codes', anything else be sure to write down. Could be sucking air in the fuel, bad throttle position sensor, failing cam sensor, rubbed spot on the harness, ground issue from the engine swap, loose connectors on top of the injectors to name a few things.
    Let us know the answers to the first questions and we'll get you going.
