1996 kenworth w900L a/c problems!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by joey8686, Sep 1, 2018.
  1. joey8686
    joey8686 Light Load Member
    131
    154
    Jul 1, 2014
    Hello y’all I recently picked up a 96 w900L,Great Truck except for the a/c, it has charge in the system but I’m not getting power to the compressor, I can hookup power to the compressor and it works fine and blows cold. Does anyone know what fuses or relays are for the a/c ? Or have a wiring diagram for the system ? ? There’s 2 switches on the line by the rad,one has power and the other one does not one will cut the engine fan on if I stick a paper clip in it but won’t turn the Ac on. Anyone ever come across this problem?
  3. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    One is high or low pressure switch and one is bianary switch controls fan and high or low. Sorry can’t remember. Ask kenworth. The one that you jumped to engage fan is supposed to engage when pressure is high.If you run compressor a while at idle it should turn fan on when pressure is high if its good. That’s not to say if it’s a bianary switch that the other function of controlling compressor is good. Basically one is low pressure and one is high pressure except one of them has another function to turn compressor on and off .pressure gets too high fan kicks on then compressor kicks off . Pressure comes down compressor kicks on fan goes off. Power goes thru one of them to power compressor. Without my book I can’t say for sure. But it may be one is fan switch and other is high and low switch Some of the old trucks had trianary switches. I would check for power coming into the other switch and jumping it if it works it’s the switch . Do yourself a favor buy both switches put them on.You change without losing any Freon. If it’s then fixed you can go back and figure out which one as bad and toss the other one.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Those two switches are the high and low pressure switches. Check the wires running to them the whole length of them. They are known to break inside the wire covering. Or at the plugs. Do a wiggle test to see if it engages. If not like the other post said one of the switches may be bad. You can screw them off and hook a test light to them and take a small screwdriver and push in the pin to see if they are bad or good.
    snowman_w900 and BoxCarKidd Thank this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Never thought of that switch test.
