1997 Fld 3406e needs help
Discussion in 'Freightliner Forum' started by brknwng, Apr 21, 2014.
  1. brknwng
    brknwng Bobtail Member
    39
    4
    Apr 21, 2014
    I have a1997 FLD with 3406E 5EK! Just had some work done and drove it home ran really good! After getting home it was idling and quit and wouldn't start no check engine light when key is on. I have a good ECM from a 98 1LW so, I disconnect the batteries and hookup the 1lw ECM and she fires right up and idle well but, has raw fuel smoke and will cut out up to a certain rpm. And stops the smoking after you get speedup! the 97 has a 9 speed with 340 rears 24.5 LP rubber and the 98 of course was a 1lw with a 10 over with 3.90 rears and 22.5 Lp rubber! Question is if I have the ECM programmed to this engine will that raw fuel go away. Is there that much difference in the injectors that it should do so! Before it quit all was well! Thanks!
  3. wore out
    wore out Numbered Classic
    17,518
    218,747
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The raw fuel smoke and cut out to a certain rpm screams timing issues. Most likely advanced, naturally you need to program the ecm to match the setup you are running. I would look a little deeper into why the 5ek ECM quit. That's awful fishy have work done and then it quits soon as you get home. I think CAT can flash the 1LW to a 5ek file.
  4. brknwng
    39
    4
    Apr 21, 2014
    Don't know much about the truck! Bought it to replace my 98 I destryed in Wyoming in November. I may have spiked the ECM or the mechanic may have with a battery charge. For some reason someone turned the batteries around!
  5. brknwng
    39
    4
    Apr 21, 2014
    Mechanic came by today and appears that the number one injector is dead! Mechanic ask me if I had the code to get into the ECM but, I don't! I don't have the truck this ECM came out of so, I don't know the engine serial no#. Is there anyone that access to the info if They had the truck vin! 1FUYDXYB3WL981639 ? If I had engine serial maybe I could fiind a code! I'm not trying to create a hotrod. Just get back to work after 5 months! Thanks for any help! Bob
