1998 379 Peterbilt King Pin Greasing Problem
Discussion in 'Peterbilt Forum' started by Cindy, Jan 5, 2019.
  1. Cindy
    Cindy Light Load Member
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Hi everyone,
    I have a 1998 379 Peterbilt 3406E cat. The top king pin on the driver side when I try to grease it the cap popped off. Then I put a new cap on it, it won't take the grease, I jacked it up to take the pressure off. Any suggestions on how to get grease in it? Thanks
  3. snowwy
    snowwy Road Train Member
    20,618
    13,339
    Jul 6, 2009
    Are you talking about the zirk?
    austinmike Thanks this.
  4. 201
    201 Road Train Member
    12,852
    26,454
    Apr 16, 2014
    high plains colorado
    I've warmed zirk fittings with a propane torch and they took grease. Don't burn the truck down, clean the grease off 1st, but it works.
    Bakerman and Cam Roberts Thank this.
  5. InTooDeep
    4,981
    37,364
    Jan 17, 2016
    Carmichael CA
    Also if the tiny ball at the end of the zirk gets stuck try pushing it easy with an awl BTDT
  6. snowwy
    20,618
    13,339
    Jul 6, 2009
    Pull the zirk out and clean the inside also. Use a pick.
    It's pretty common if not lubed often enough. To harden up inside there.
  7. Cindy
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Hi snowwy, when I try to grease it the grease is not going down to the king pin.
  8. snowwy
    20,618
    13,339
    Jul 6, 2009
    Hi cindy, It's probably hardened up inside the king pin hole. Since you installed a new zirk.
  9. Cindy
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Hi Everyone,
    Sorry if I'm not relaying my problem correctly. Grease does go through the grease fitting (zirk) just fine. When I try to grease it the grease goes in but it does not come out all the way at the bottom like it does when I grease the passenger side. It gets hard to use the grease gun and then the threaded cap pops off. I tack welded the cap back on and when I try greasing it the grease comes through the cap around the threads. Thank you all for your help, I appreciate it.
  10. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Sounds like time to take apart and inspect that King pin, find what's wrong inside.
  11. wore out
    wore out Numbered Classic
    17,517
    218,710
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I would check it for slack though that isn't your problem. If it's time for replacement that would cure the problem all in 1 move. Pull both caps and the jack bolt. Drive the pin down past top of spindle but not out. Lightly hone the crud out of the bushing knock it back up and grease. Old grease will harden and the only way to get it is the old fashioned way.
