1998 379 Peterbilt King Pin Greasing Problem
Discussion in 'Peterbilt Forum' started by Cindy, Jan 5, 2019.
  1. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    If it won't take grease than the pin more than likely is either rusted or packed with dirt and or hardened grease.The right thing to do is remove the pin and see what the problem is.That being said,you can remove the zirk(grease fitting)and try to spray penatrating oil in the hole and all over the pivot point.Like Semi Retired said you can even put heat.Center the heat at the end of the pin,once you get it nice and warm, again with the oil(I like PB Blast).Rock it up and down,spray some more.Put zirk back, grease.If that doesn't work, pull the pin.
    201 Thanks this.
  3. KentWorthinton
    KentWorthinton Bobtail Member
    Jan 24, 2019
    If you're using a manual grease gun, try putting some auto trans fluid in the gun, hold it upside down and pump it in. If it is hardened grease it will sometimes push through. If it has had king pins replaced recently they may have put the seals in upside down.
    Tombstone69 Thanks this.
  4. weirdpuckett
    weirdpuckett Heavy Load Member
    997
    498
    Jul 14, 2010
    Okay.....Im gonna ask this question.....cuz I dint know what a "king pin" is ......other than the thing on the trailer .....which you all are clearly not referring to here.....
  5. 201
    201 Road Train Member
    12,820
    26,397
    Apr 16, 2014
    high plains colorado
    King pin is also the pin that holds the steering spindle to the axle.
    King Pin Replacement
  6. weirdpuckett
    997
    498
    Jul 14, 2010
    Ahhhhhhh......thx ....I hadnt realized that is what they are called....
    201 Thanks this.
  7. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Buy a harbor freight air grease gun. I have one and been using it for years. It’s very very very powerful. If that can’t push the grease through, then you have a problem that requires dissemble
