1998 9400 with a C15 AC Problems
Discussion in 'International Forum' started by kandbtransport, Jun 19, 2013.
  1. kandbtransport
    kandbtransport Bobtail Member
    Jun 19, 2013
    OK I have a problem it's blowing ice cold out of the start of the blower motor I just replaced that blower motor. It's like 36 degrees at the start and by the time it makes it to the drivers side it's like 70 just a little cool and not really cooling the truck down on high. What does it sound like to you? The Freon is all charged no leaks no where.
  3. morr2fab
    morr2fab Medium Load Member
    338
    110
    Oct 3, 2012
    Your truck should have a air filter for cab, both inside air and outside air. May need to check those. Also wouldnt hurt to have a PRO (spend the money and enjoy the honey) check the freon again. Low freon level will cause the bottom of the evaperator to be colder than the top. By as much as 50 degrees. Good luck.
  4. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    also check the tubing behind the dash they can split and you will loose alot of flow and if dash is black putting a carpet on the dash will make a big diff
  5. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Check the duct work going to the vents might be falling apart
  6. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Are your heater lines turned off?
  7. kandbtransport
    Jun 19, 2013
    I had a pro look at it and he is scratching his head. We put one of the newest Hi Tech AC machines thats shows everything and it's showing everything normal. The only thing we have not done is tore into the duct work.. Yes heater lines are off.
    cetanediesel Thanks this.
  8. morr2fab
    338
    110
    Oct 3, 2012
    I did ac work (Thats why I wrote"PRO") so without looking at your truck I dont know. Hope you find the problem. Happy Trucking
