1998 kenworth voltage meter dropping
Discussion in 'Kenworth Forum' started by irishluck09, May 10, 2026.
  1. irishluck09
    irishluck09 Medium Load Member
    307
    185
    Nov 24, 2019
    So this is a fun one.
    1998 kw w9 n14 cummins
    In the past week or so I guess i may have sprung up a short maybe?
    Anytime I flip my switch for the headlights, or the side/tail lamps or turn on the blower to the heat/AC, my voltage drops from 14v all the way down to 12v and then my water temp gauge starts rising from its typical 180* to just under 210* forcing my fan to kick on.
    Im not even sure where to start here lol with those same switches and blower flipped on I have checked the alternator and batteries which both show 14v charging. Everything behind the dash panels seem fine. Checked wiring by the headlights, dont see anything. Definitely confused here.
  3. AModelCat
    165,896
    Personally I would start with checking the charging circuit via voltage drop checks. Thing is you need the system under a decent load so flip on every accessory you can with the truck running. Put a digital multimeter lead on the alternator positive stud and the other on each battery positive post. Any voltage you see indicates a voltage drop (loss). Basically a poor connection. Do the same on the ground side - alternator housing (or ground stud if it has one) to each battery negative. Same story, any voltage showing on the meter is a loss.
    If you read a voltage during the above tests you can work back from alternator to batteries until the meter starts reading no (or very low) voltage, that would indicate the issue lies between your last 2 test points.
    You can test for voltage drops on any circuit that way, even cab or engine grounds.
    Obviously use care and attention when working with test leads around the fan, belts, moving parts etc. Don't want to get caught in those.
  4. abyliks
    abyliks Road Train Member
    4,185
    9,897
    May 2, 2010
    ludlow MA
    Honestly I don’t think I’ve ever driven a KW with one that worked correctly, they all drop, I ordered a 12v charger base for my phone charger that displays volts and it always sits ~14 no matter what the gauge says
