1998 T2000 Electrical Problems
Discussion in 'Kenworth Forum' started by rshackleford, Dec 8, 2011.
  1. rshackleford
    rshackleford Bobtail Member
    27
    Nov 30, 2010
    My T2000 has a electric problem somewhere. The odometer is intermittent, the cruise won't work, and the jake brake doesn't work.
    Anyone have any ideas?
    Can anyone help me find an electric schematic for the truck?
  3. Oscar the KW
    Oscar the KW No Filter
    11,713
    24,835
    May 19, 2011
    Electrical problems are the worst. First thing I would do is check every ground coming off every harnes you can get to. Make sure they are clean. I can't think of anything else that those three things would have in common. But I'm no expert.
  4. Sparkz
    Sparkz Light Load Member
    76
    15
    Jul 10, 2011
    New Zealand
    If speedo reads, but odometer doesn't I would suspect a gauge fault.
    Check the clutch switch. If this is stuck on, the cruise and Jakes wont work.
  5. rshackleford
    27
    Nov 30, 2010
    It could be two separate problems though.
  6. cowcatcher
    cowcatcher Light Load Member
    You have two different problems.
  • Draft saved Draft deleted
