1999 9300 abs issue
Discussion in 'International Forum' started by Rc1234, Mar 3, 2019.
  1. Rc1234
    Rc1234 Bobtail Member
    18
    4
    May 31, 2018
    It has bendix ABS system, and the ecu shows left front sensor fault...changed sensor, replaced some bad wiring, reset with magnet, and light stays on, same fault code...any suggestions?
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Sometimes they have to be driven over 5 mph so the ABS can see proper wheel speed. Left front sensor is at pins J1 and J2 of the ABS connector. This is where you need to measure your total circuit from. Sensors are about 900 to 1800 ohms in resistance and totally open to ground and power so no shorts of any kind, so this also needs to be measure at the ECU. So you probably have more wiring issues. ECU's do go bad, but that is rare and should only suspected after the wiring is confirmed good.
  4. Rc1234
    18
    4
    May 31, 2018
    Sorry, I meant right front sensor...
  5. Heavyd
    7,829
    6,280
    Feb 4, 2009
    H3 and H2.
    Rc1234 Thanks this.
  6. Rc1234
    18
    4
    May 31, 2018
    Nothing at h3 and h2, so more wiring issues as there is good reading along frame rail where there was a break in wiring...must be somewhere around crossmember area..haven’t had time to look further yet..
    Heavyd Thanks this.
  7. Rc1234
    18
    4
    May 31, 2018
    Finally found problem (last year)...found broken wires along frame rail near clutch linkage...working fine since..thanks all
