1999 Kenworth T800 check engine code?
Discussion in 'Kenworth Forum' started by eriksat1, May 17, 2013.
  1. eriksat1
    eriksat1 Bobtail Member
    I have a 1999 Kenworth T800 with a Cat C12 engine. Check engine light is on. All fluid levels are good, new oil change and new filters, runs good, oil pressure is good.
    I turn the key on then hit the resume switch the code flashes once then pause then flash two times pause then once pause then flashes four times. So 1-2 then 1-4? Anyone know what that is?
  3. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    12 is for coolant level invalid signal.
    14 is for current high or low for jake solinoid
