1LW cat overhaul
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ole Skool, Mar 12, 2021.
  1. Ole Skool
    Ole Skool Bobtail Member
    21
    8
    Apr 3, 2019
    Need help overhaul 1LW cat
    stillwurkin Thanks this.
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Start a go fund me account? $$ Jk.
    Dave_in_AZ Thanks this.
  4. Troy_
    Troy_ Road Train Member
    1,226
    9,253
    Dec 13, 2017
    Roma, Alberta.
    we had a lot of trouble with our 1LW engines. broken cranks and blown head gaskets. good luck with the rebuild
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    15-25 k depending on shop, the help you need is financial not us
  6. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Anyone ever replace the crankshaft dampner ?
    maconhadalata Thanks this.
  7. Troy_
    1,226
    9,253
    Dec 13, 2017
    Roma, Alberta.
    we had 2 of them go down with similar hours. A '98 and a '99
    We didn't try it, just swapped them out for 6NZ engines.
  8. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    You gotta be more specific man, what kind of help you looking for?
    Prices?
    Kits?
    Places to do it?
    Wanna do it yourself?
    Caterpillar Cowboy and AModelCat Thank this.
  9. AModelCat
    164,925
    Gotta love those posts.
  10. Ole Skool
    21
    8
    Apr 3, 2019
    Kits, head, fire rings or not, 1 or 2 piece piston
  11. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    I used IPD one piece steel pistons, my head was newer so I didn't change that. Buy if I needed one now I'd probably go with a APC (American premium castings) guy by the name of Robert Calexico seems to be the go to guy. Lots of people running his heads. A few have had problems but Robert has bent over backwards for most to fix any issues. He has several different stages of heads depending on HP.
    I have no experience with O-ringed heads. But for factory HP I don't think they are necessary. But some guys really like them and say you will never have to worry about blowing a head gasket again. Make sure your liner height is correct first and foremost. If its never been apart I'm sure you will need to cut the counter bores. Cat head gasket and ARP head bolts or i think IPD is offering some special treated headbolts now too.
    I'm running 700ish hp on my 6nz with IPD one piece kit. Haven't had any trouble and I'm hard on that engine
    Oxbow and Stray_Dog Thank this.
